NetApp solutions for SAP
Contributors netapp-mschoen
Single host
This section describes the configuration of the NetApp storage system specific to SAP HANA single-host systems
LUN Overview
The following table shows the LUN configuration of a single-host SAP HANA system.
Purpose LUNs LVM logical volume
Data
FC5_data_mnt00001_1
FC5_data_mnt00001_2
FC5_data_mnt00001-vol
Log
FC5_log_mnt00001_1
FC5_log_mnt00001_2
FC5_log_mnt00001-vol
Shared
FC5_shared
n/a
Note With the described configuration, the /usr/sap/SID1 directory in which the default home directory of user SID1adm is stored, is on the local disk. In a disaster recovery setup with disk-based replication, NetApp recommends creating an additional LUN for the /usr/sap/SID1 directory so that all file systems are on the central storage.
Note If SAP Local Secure Store service (LSS) is used, the /lss/shared/SID directory, the default installation directory of LSS, is on the local disk. In a disaster recovery setup with disk-based replication, NetApp recommends creating an additional LUN for the /lss/shared/SID directory so that all file systems are on the central storage.
Creating LUNs and mapping LUNs to initiator groups
You can use NetApp ONTAP System Manager to create storage volumes and LUNs and the map them to the igroups of the servers and the ONTAP CLI.
Creating LUNs and mapping LUNs to initiator groups using the CLI
This section shows an example configuration using the command line with ONTAP 9 for a SAP HANA single host system with SID FC5 using LVM and two LUNs per LVM volume group:
  1. Create all LUNs.
    lun create -path  FC5_data_mnt00001_1 -size 1t -ostype linux  -class regular
    lun create -path FC5_data_mnt00001_2 -size 1t -ostype linux  -class regular
    lun create -path FC5_log_mnt00001_1 -size 260g -ostype linux  -class regular
    lun create -path FC5_log_mnt00001_2 -size 260g -ostype linux  -class regular
    lun create -path FC5_shared -size 260g -ostype linux  -class regular
    Note Disable autonomous ransom protection for these LUNs using the GUI
  2. Create the initiator group for all servers belonging to system FC5.
    lun igroup create -igroup HANA-FC5 -protocol fcp -ostype linux -initiator 10000090fadcc5fa,10000090fadcc5fb -vserver svm1
  3. Map all LUNs to created initiator group.
    lun map -path FC5_data_mnt00001_1 -igroup HANA-FC5
    lun map -path FC5_data_mnt00001_2 -igroup HANA-FC5
    lun map -path FC5_log_mnt00001_1 -igroup HANA-FC5
    lun map -path FC5_log_mnt00001_2 -igroup HANA-FC5
    lun map -path FC5_shared -igroup HANA-FC5
Creating LUNs and mapping LUNs to initiator groups using the GUI
This section shows an example configuration using ONTAP System Manager for a SAP HANA single host system with SID FC5 using LVM and two LUNs per LVM volume group:
  1. Log on to the ONTAP System Manager of your ONTAP Cluster and choose Storage from the left menu.
    1. Press Add
      ONTAP System Manager - Storage
  2. Choose More options
    ONTAP System Manager - Add Storage
  3. Provide the required information:
    1. the name of the data LUNs, e.g.FC5_data_mnt00001
    2. the amount of LUNs to be combined with LVM, e.g. 2
    3. the size of each LUN, e.g. 1000 GB
    4. choose SCSI (FC or iSCSI)
    5. choose Linux as Host Operating system
    6. choose New host for the Host mapping option, provide a nam, e.g FC5_host, pick or add the desired initiators
    7. Keep Schedule snapshots unchecked
    8. press Add
      ONTAP System Manager - Create Data LUNs
  4. After successful creation of the data LUNs create the log LUNs by pressing Add
    ONTAP System Manager - Create log LUNs
  5. Provide the required information:
    1. teh name of the log LUNs, e.g. FC5_log_mnt00001
    3. the size of each LUN, e.g. 260 GB
    4. choose Linux as Host Operating system
    5. choose the previously created mapping FC5_host for the Host mapping option
    6. press Add
  6. After successful creation of the log LUNs create the shared LUN by pressing Add
    ONTAP System Manager - Create shared LUN
  7. Provide the required information:
    1. the name of the shared LUN, e.g.FC5_shared
    2. the amount of LUNs, e.g. 1
    3. the size of the LUN, e.g. 520 GB
    6. press Add
      ONTAP System Manager - Create shared LUNs
All required LUNs for a SAP HANA single-host system have been created.
ONTAP System Manager - LUN Overview
Disable Autonomous Ransomware Protection for all data und log LUNS
Open the context menu of each data and log LUN and disable ransomware-protection
