NetApp solutions for SAP
Contributors netapp-mschoen
Multiple hosts
This section describes the configuration of the NetApp storage system specific to SAP HANA multiple-hosts systems
Volume and LUN configuration for SAP HANA multiple-host systems
The following figure shows the volume configuration of a 4+1 multiple-host SAP HANA system. The data volumes and log volumes of each SAP HANA host are distributed to different storage controllers. For example, the volume SID_data_mnt00001 is configured on controller A and the volume SID_log_mnt00001 is configured on controller B. One LUN is configured within each volume.
The /hana/shared volume must be accessible by all HANA hosts and is therefore exported by using NFS. Even though there are no specific performance KPIs for the /hana/shared a file system, NetApp recommends using a 10Gb Ethernet connection.
Note If only one storage controller of an HA pair is used for the SAP HANA system, data and log volumes can also be stored on the same storage controller.
Figure showing input/output dialog or representing written content
For each SAP HANA host, a data volume and a log volume are created. The /hana/shared volume is used by all hosts of the SAP HANA system. The following figure shows an example configuration for a 4+1 multiple-host SAP HANA system.
Purpose Aggregate 1 at Controller A Aggregate 2 at Controller A Aggregate 1 at Controller B Aggregate 2 at Controller B
Data and log volumes for node 1
Data volume: SID_data_mnt00001
Log volume: SID_log_mnt00001
Data and log volumes for node 2
Log volume: SID_log_mnt00002
Data volume: SID_data_mnt00002
Data and log volumes for node 3
Data volume: SID_data_mnt00003
Log volume: SID_log_mnt00003
Data and log volumes for node 4
Log volume: SID_log_mnt00004
Data volume: SID_data_mnt00004
Shared volume for all hosts
Shared volume: SID_shared
The next table shows the configuration and the mount points of a multiple-host system with four active SAP HANA hosts.
LUN or Volume Mount point at SAP HANA host Note
LUN: SID_data_mnt00001
/hana/data/SID/mnt00001
Mounted using storage connector
LUN: SID_log_mnt00001
/hana/log/SID/mnt00001
LUN: SID_data_mnt00002
/hana/data/SID/mnt00002
LUN: SID_log_mnt00002
/hana/log/SID/mnt00002
LUN: SID_data_mnt00003
/hana/data/SID/mnt00003
LUN: SID_log_mnt00003
/hana/log/SID/mnt00003
LUN: SID_data_mnt00004
/hana/data/SID/mnt00004
LUN: SID_log_mnt00004
/hana/log/SID/mnt00004
Volume: SID_shared
/hana/shared/SID
Mounted at all hosts using NFS and /etc/fstab entry
Note With the described configuration, the /usr/sap/SID directory in which the default home directory of user SIDadm is stored is on the local disk for each HANA host. In a disaster recovery setup with disk-based replication, NetApp recommends creating four additional subdirectories in the SID_shared volume for the /usr/sap/SID file system so that each database host has all its file systems on the central storage.
Note If SAP Local Secure Store service (LSS) is used, the /lss/shared/SID directory must be accessible at all hosts. NetApp recommends creating a volume for the /lss/shared/SID directory and mount it at all hosts using NFS.
Volume and LUN configuration for SAP HANA multiple-host systems using Linux LVM
The Linux LVM can be used to increase performance and to address LUN size limitations. The different LUNs of an LVM volume group should be stored within a different aggregate and at a different controller.
LUNs of an LVM volume group should be stored within a different aggregate and at a different controller. The following table shows an example for two LUNs per volume group for a 2+1 SAP HANA multiple host system.
Note It is not necessary to use LVM to combine several LUN to fulfil the SAP HANA KPIs, but it is recommended.
Log2 volume: SID_log2_mnt00001
Data2 volume: SID_data2_mnt00001
Log2 volume: SID_log2_mnt00002
Data2 volume: SID_data2_mnt00002
Volume options
The volume options listed in the following table must be verified and set on all volumes used for SAP HANA.
Action ONTAP 9
Disable automatic Snapshot copies
vol modify –vserver <vserver-name> -volume <volname> -snapshot-policy none
Disable visibility of Snapshot directory
vol modify -vserver <vserver-name> -volume <volname> -snapdir-access false
Disable ransomware protection, except of the SID_shared volume
vol modify -vserver <vserver-name> -volume <volname> -anti-ransomware-state disabled
Note The example below sets these options during volume creation
Creating LUNs, volumes, and mapping LUNs to initiator groups
You can use NetApp ONTAP System Manager to create storage volumes and LUNs and the map them to the igroups of the servers and the ONTAP CLI. This guide describes the usage of the CLI.
Creating LUNs, volumes, and mapping LUNs to igroups using the CLI
This section shows an example configuration using the command line with ONTAP 9 for a 2+1 SAP HANA multiple host system with SID FC5 using LVM and two LUNs per LVM volume group.
  1. Create all necessary volumes.
    vol create -volume FC5_data_mnt00001 -aggregate aggr1_1 -size 1200g  -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_log_mnt00002  -aggregate aggr2_1 -size 280g  -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_log_mnt00001  -aggregate aggr1_2 -size 280g -snapshot-policy none -foreground true -encrypt false -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_data_mnt00002  -aggregate aggr2_2 -size 1200g -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_data2_mnt00001 -aggregate aggr1_2 -size 1200g -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_log2_mnt00002  -aggregate aggr2_2 -size 280g -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none-anti-ransomware-state disabled
    vol create -volume FC5_log2_mnt00001  -aggregate aggr1_1 -size 280g -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_data2_mnt00002  -aggregate aggr2_1 -size 1200g -snapshot-policy none -foreground true -encrypt false  -snapdir-access false -space-guarantee none -anti-ransomware-state disabled
    vol create -volume FC5_shared -aggregate aggr1_1 -size 512g -state online -policy default -snapshot-policy none -junction-path /FC5_shared -encrypt false  -snapdir-access false -space-guarantee none
  2. Create all LUNs.
    lun create -path  /vol/FC5_data_mnt00001/FC5_data_mnt00001   -size 1t -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_data2_mnt00001/FC5_data2_mnt00001 -size 1t -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_data_mnt00002/FC5_data_mnt00002 -size 1t -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_data2_mnt00002/FC5_data2_mnt00002 -size 1t -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_log_mnt00001/FC5_log_mnt00001 -size 260g -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_log2_mnt00001/FC5_log2_mnt00001 -size 260g -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_log_mnt00002/FC5_log_mnt00002 -size 260g -ostype linux -space-reserve disabled
    lun create -path /vol/FC5_log2_mnt00002/FC5_log2_mnt00002 -size 260g -ostype linux -space-reserve disabled
  3. Create the igroup for all servers belonging to system FC5.
    lun igroup create -igroup HANA-FC5 -protocol fcp -ostype linux -initiator 10000090fadcc5fa,10000090fadcc5fb, 10000090fadcc5c1,10000090fadcc5c2,  10000090fadcc5c3,10000090fadcc5c4 -vserver hana
  4. Map all LUNs to the created igroup.
    lun map -path  /vol/FC5_data_mnt00001/FC5_data_mnt00001    -igroup HANA-FC5
    lun map -path /vol/FC5_data2_mnt00001/FC5_data2_mnt00001  -igroup HANA-FC5
    lun map -path /vol/FC5_data_mnt00002/FC5_data_mnt00002  -igroup HANA-FC5
    lun map -path /vol/FC5_data2_mnt00002/FC5_data2_mnt00002  -igroup HANA-FC5
    lun map -path /vol/FC5_log_mnt00001/FC5_log_mnt00001  -igroup HANA-FC5
    lun map -path /vol/FC5_log2_mnt00001/FC5_log2_mnt00001  -igroup HANA-FC5
    lun map -path /vol/FC5_log_mnt00002/FC5_log_mnt00002  -igroup HANA-FC5
    lun map -path /vol/FC5_log2_mnt00002/FC5_log2_mnt00002  -igroup HANA-FC5
