Learn about provisioning storage for applications deployed on Red Hat OpenShift
NetApp integrates with Red Hat OpenShift using the Trident Storage Orchestrator to provide persistent storage for containerized applications. Supported storage options include ONTAP-based systems such as AFF and FAS, and ONTAP Select and Cloud Volumes ONTAP for virtualized and cloud environments. Cloud-native services like Amazon FSx for NetApp ONTAP, Azure NetApp Files, and Google Cloud NetApp Volumes are also supported.
AFF and FAS systems run NetApp ONTAP and provide storage for both file-based (NFS) and block-based (iSCSI) use cases.
Cloud Volumes ONTAP and ONTAP Select provide the same benefits in the cloud and virtual space respectively.
Amazon FSx for NetApp ONTAP, Azure NetApp Files, and Google Cloud NetApp Volumes provide file-based storage in the cloud.
NetApp Element storage systems provide for block-based (iSCSI) use cases in a highly scalable environment.
Each storage system in the NetApp portfolio can ease both data management and movement between on-premises sites and the cloud, ensuring that your data is where your applications are. |
The following pages have additional information about the NetApp storage systems validated in the Red Hat OpenShift with NetApp solution:
