Converge vSphere cluster to VCF management domain using the VCF Installer Tool
Contributors sureshthoppay
Converge an existing vSphere cluster to a VCF management domain using the VCF Installer Tool. You'll validate the vCenter appliance, deploy the VCF Installer, reuse existing components and install new ones to complete the VCF management domain.
Based on the components that are already deployed in your environment, the VCF Installer Tool will determine which components can be reused and which components need to be installed. The VCF Installer Tool will also validate the existing vCenter appliance and ensure that it meets the requirements for convergence.
Follow the steps documented at Converging your existing vSphere infrastructure to a VCF management domain to complete the convergence process.
VCF Upgrade Planning Tool provides the high-level steps to complete the convergence process based on the inputs you provide.
