vSphere VMFS Datastore - iSCSI Storage backend with ONTAP
This section covers the creation of a VMFS datastore with ONTAP iSCSI storage.
For automated provisioning, use the following script: Ansible Playbook.
What you need
The basic skills necessary to manage a vSphere environment and ONTAP.
An ONTAP storage system (FAS/AFF/CVO/ONTAP Select/ASA) running {ontap_version}
ONTAP credentials (SVM name, userID, and password)
ONTAP network port, SVM, and LUN information for iSCSI
vCenter Server credentials
vSphere host(s) information
{vsphere_version}
iSCSI VMKernel adapter IP information
Network switch(es)
With ONTAP system network data ports and connected vSphere hosts
VLAN(s) configured for iSCSI
(Optional) link aggregation configured for ONTAP network data ports
ONTAP Tool for VMware vSphere deployed, configured, and ready to consume
Steps
Check compatibility with the Interoperability Matrix Tool (IMT).
Complete the following ONTAP and vSphere tasks.
ONTAP tasks
Verify the ONTAP license for iSCSI.
Use the
system license showcommand to check if iSCSI is listed. -
Use
license add -license-code <license code>to add the license.
Verify that iSCSI network logical interfaces are available on the SVM.
When an SVM is created using the GUI, iSCSI network interfaces are also created. -
Use the
Network interfacecommand to view or make changes to the network interface.Two iSCSI network interfaces per node are recommended. -
Create an iSCSI network interface. You can use the default-data-blocks service policy.
Verify that the data-iscsi service is included in the service policy. You can use
network interface service-policy showto verify. -
Create and map the LUN. Skip this step if you are using ONTAP tools for VMware vSphere. Repeat this step for each LUN.
VMware vSphere tasks
Verify that at least one NIC is available for the iSCSI VLAN. Two NICs are preferred for better performance and fault tolerance.
Identify the number of physical NICs available on the vSphere host.
Configure the iSCSI initiator. A typical use case is a software iSCSI initiator.
Verify that iSCSI portgroups are available.
We typically use a single virtual switch with multiple uplink ports.
Use 1:1 adapter mapping.
Verify that iSCSI VMKernel adapters are enabled to match the number of NICs and that IPs are assigned.
Bind the iSCSI software adapter to the iSCSI VMKernel adapter(s).
Provision the VMFS datastore with ONTAP Tools. Repeat this step for all datastores.
Reference Video:
What's next?
After these the tasks are completed, the VMFS datastore is ready to consume for provisioning virtual machines.
## Disclaimer: Sample script for reference purpose only.
- hosts: '{{ vsphere_host }}'
name: Play for vSphere iSCSI Configuration
connection: local
gather_facts: false
tasks:
# Generate Session ID for vCenter
- name: Generate a Session ID for vCenter
uri:
url: "https://{{ vcenter_hostname }}/rest/com/vmware/cis/session"
validate_certs: false
method: POST
user: "{{ vcenter_username }}"
password: "{{ vcenter_password }}"
force_basic_auth: yes
return_content: yes
register: vclogin
# Generate Session ID for ONTAP tools with vCenter
- name: Generate a Session ID for ONTAP tools with vCenter
uri:
url: "https://{{ ontap_tools_ip }}:8143/api/rest/2.0/security/user/login"
method: POST
return_content: yes
body_format: json
body:
vcenterUserName: "{{ vcenter_username }}"
vcenterPassword: "{{ vcenter_password }}"
register: login
# Get existing registered ONTAP Cluster info with ONTAP tools
- name: Get ONTAP Cluster info from ONTAP tools
uri:
url: "https://{{ ontap_tools_ip }}:8143/api/rest/2.0/storage/clusters"
method: Get
return_content: yes
headers:
vmware-api-session-id: "{{ login.json.vmwareApiSessionId }}"
register: clusterinfo
- name: Get ONTAP Cluster ID
set_fact:
ontap_cluster_id: "{{ clusterinfo.json | json_query(clusteridquery) }}"
vars:
clusteridquery: "records[?ipAddress == '{{ netapp_hostname }}' && type=='Cluster'].id | [0]"
- name: Get ONTAP SVM ID
set_fact:
ontap_svm_id: "{{ clusterinfo.json | json_query(svmidquery) }}"
vars:
svmidquery: "records[?ipAddress == '{{ netapp_hostname }}' && type=='SVM' && name == '{{ svm_name }}'].id | [0]"
- name: Get Aggregate detail
uri:
url: "https://{{ ontap_tools_ip }}:8143/api/rest/2.0/storage/clusters/{{ ontap_svm_id }}/aggregates"
method: GET
return_content: yes
headers:
cluster-id: "{{ ontap_svm_id }}"
when: ontap_svm_id != ''
register: aggrinfo
- name: Select Aggregate with max free capacity
set_fact:
aggr_name: "{{ aggrinfo.json | json_query(aggrquery) }}"
vars:
aggrquery: "max_by(records, &freeCapacity).name"
- name: Convert datastore size in MB
set_fact:
datastoreSizeInMB: "{{ iscsi_datastore_size | human_to_bytes/1024/1024 | int }}"
- name: Get vSphere Cluster Info
uri:
url: "https://{{ vcenter_hostname }}/api/vcenter/cluster?names={{ vsphere_cluster }}"
method: GET
return_content: yes
body_format: json
headers:
vmware-api-session-id: "{{ vclogin.json.value }}"
when: vsphere_cluster != ''
register: vcenterclusterid
- name: Create iSCSI VMFS-6 Datastore with ONTAP tools
uri:
url: "https://{{ ontap_tools_ip }}:8143/api/rest/3.0/admin/datastore"
method: POST
return_content: yes
status_code: [200]
body_format: json
body:
traditionalDatastoreRequest:
name: "{{ iscsi_datastore_name }}"
datastoreType: VMFS
protocol: ISCSI
spaceReserve: Thin
clusterID: "{{ ontap_cluster_id }}"
svmID: "{{ ontap_svm_id }}"
targetMoref: ClusterComputeResource:{{ vcenterclusterid.json[0].cluster }}
datastoreSizeInMB: "{{ datastoreSizeInMB | int }}"
vmfsFileSystem: VMFS6
aggrName: "{{ aggr_name }}"
existingFlexVolName: ""
volumeStyle: FLEXVOL
datastoreClusterMoref: ""
headers:
when: ontap_cluster_id != '' and ontap_svm_id != '' and aggr_name != ''
register: result
changed_when: result.status == 200
