vSphere VMFS Datastore - NVMe/FC with ONTAP
This section covers the creation of a VMFS datastore with ONTAP storage using NVMe/FC.
What you need
Basic skills needed to manage a vSphere environment and ONTAP.
An ONTAP Storage System (FAS/AFF/CVO/ONTAP Select/ASA) running {ontap_version}
ONTAP credentials (SVM name, userID, and password)
ONTAP WWPN for host, target, and SVMs and LUN information
vCenter Server
vSphere host(s) information ({vsphere_version})
Fabric switch(es)
With ONTAP FC data ports and vSphere hosts connected.
With the N_port ID virtualization (NPIV) feature enabled.
Create a single initiator target zone.
Create one zone for each initiator (single initiator zone).
For each zone, include a target that is the ONTAP FC logical interface (WWPN) for the SVMs. There should be at least two logical interfaces per node per SVM. DO not use the WWPN of physical ports.
Provision VMFS datastore
Check compatibility with the Interoperability Matrix Tool (IMT).
ONTAP tasks
Verify the ONTAP license for FCP.
Use thesystem license showcommand and check if NVMe_oF is listed.
Uselicense add -license-code <license code>to add a license. -
Verify that NVMe protocol is enabled on the SVM.
Verify that NVMe/FC Logical Interfaces are available on the SVMs.
Use
Network Interface showto verify the FCP adapter. -
When an SVM is created with the GUI, logical interfaces are as part of that process.
To rename the network interface, use the command
Network Interface modify.
VMware vSphere Tasks
Verify that HBA drivers are installed. VMware supported HBAs have the drivers deployed out of the box and should be visible at Storage Adapter Information
Perform vSphere Host NVMe driver installatioln and validation tasks
