NetApp Solution Automation
Contributors kulkarnn Download PDF of this page
Procedure
  1. Requirements for the Ansible control node,:
    1. A Ubuntu/Debian machine with the following packages installed:
      1. Python3
      2. Pip3
      3. Ansible (version greater than 2.10.0)
      4. Git
If you have a fresh Ubuntu/Debian machine without the above requirements installed, follow the below steps to setup that machine as the Ansible control node:
  1. Create a .sh file
    vi setup.sh
  2. Paste the below content in the file
    #!/bin/bash
    echo "Installing Python ------>"
    sudo apt-get -y install python3 >/dev/null
    echo "Installing Python Pip ------>"
    sudo apt-get -y install python3-pip >/dev/null
    echo "Installing Ansible ------>"
    python3 -W ignore -m pip --disable-pip-version-check install ansible >/dev/null
    echo "Installing git ------>"
    sudo apt-get -y install git >/dev/null
  3. Make the file executable
    chmod +x setup.sh
  4. Run the script (as root)
    ./setup.sh
