Adding additional data volume partitions
Contributors netapp-dorianh netapp-ivanad Download PDF of this page
Starting with SAP HANA 2.0 SPS4, additional data volume partitions can be configured. This allows you to configure two or more volumes for the data volume of an SAP HANA tenant database and scale beyond the size and performance limits of a single volume.
Using two or more individual volumes for the data volume is available for SAP HANA single-host and SAP HANA multiple-host systems. You can add additional data volume partitions at any time.
Enabling additional data volume partitions
To enable additional data volume partitions, add the following entry within global.ini by using SAP HANA Studio or Cockpit in the SYSTEMDB configuration.
[customizable_functionalities]
persistence_datavolume_partition_multipath = true
Adding the parameter manually to the global.ini file requires the restart of the database.
Volume configuration for single-host SAP HANA systems
The layout of volumes for a single-host SAP HANA system with multiple partitions is like the layout for a system with one data volume partition but with an additional data volume stored on a different aggregate as the log volume and the other data volume. The following table shows an example configuration of an SAP HANA single-host system with two data volume partitions.
Aggregate 1 at controller A Aggregate 2 at controller A Aggregate 1 at controller B Aggregate 2 at controller b
Data volume: SID_data_mnt00001
Shared volume: SID_shared
Data volume: SID_data2_mnt00001
Log volume: SID_log_mnt00001
The following table shows an example of the mount point configuration for a single-host system with two data volume partitions.
Junction path Directory Mount point at HANA host
SID_data_mnt00001
/hana/data/SID/mnt00001
SID_data2_mnt00001
/hana/data2/SID/mnt00001
SID_log_mnt00001
/hana/log/SID/mnt00001
SID_shared
usr-sap
shared
/usr/sap/SID
/hana/shared
You can create the new data volume and mount it to the namespace using either NetApp ONTAP System Manager or the ONTAP CLI.
Volume configuration for multiple-host SAP HANA systems
The layout of volumes is like the layout for a multiple- host SAP HANA system with one data volume partition but with an additional data volume stored on a different aggregate as log volume and the other data volume. The following table shows an example configuration of an SAP HANA multiple-host system with two data volume partitions.
Purpose Aggregate 1 at controller A Aggregate 2 at controller A Aggregate 1 at controller B Aggregate 2 at controller B
Data and log volumes for node 1
Data2 volume: SID_data2_mnt00001
Data and log volumes for node 2
Log volume: SID_log_mnt00002
Data2 volume: SID_data2_mnt00002
Data volume: SID_data_mnt00002
Data and log volumes for node 3
Data volume: SID_data_mnt00003
Data2 volume: SID_data2_mnt00003
Log volume: SID_log_mnt00003
Data and log volumes for node 4
Data2 volume: SID_data2_mnt00004
Log volume: SID_log_mnt00004
Data volume: SID_data_mnt00004
Shared volume for all hosts
Junction path Directory Mount point at SAP HANA host Note
SID_data_mnt00001
Mounted at all hosts
SID_data2_mnt00001
SID_log_mnt00001
SID_data_mnt00002
/hana/data/SID/mnt00002
SID_data2_mnt00002
/hana/data2/SID/mnt00002
SID_log_mnt00002
/hana/log/SID/mnt00002
SID_data_mnt00003
/hana/data/SID/mnt00003
SID_data2_mnt00003
/hana/data2/SID/mnt00003
SID_log_mnt00003
/hana/log/SID/mnt00003
SID_data_mnt00004
/hana/data/SID/mnt00004
SID_data2_mnt00004
/hana/data2/SID/mnt00004
SID_log_mnt00004
/hana/log/SID/mnt00004
SID_shared
shared
/hana/shared/SID
SID_shared
usr-sap-host1
/usr/sap/SID
Mounted at host 1
SID_shared
usr-sap-host2
/usr/sap/SID
Mounted at host 2
SID_shared
usr-sap-host3
/usr/sap/SID
Mounted at host 3
SID_shared
usr-sap-host4
/usr/sap/SID
Mounted at host 4
SID_shared
usr-sap-host5
/usr/sap/SID
Mounted at host 5
You can create the new data volume and mount it to the namespace using either ONTAP System Manager or the ONTAP CLI.
Host configuration
In addition to the tasks described in the section "Host Setup," the additional mount points and fstab entries for the new additional data volume/s must be created and the new volumes must be mounted.
  1. Create additional mount points.
    • For a single-host system, create mount points and set the permissions on the database host:
      sapcc-hana-tst-06:/ # mkdir -p /hana/data2/SID/mnt00001
      sapcc-hana-tst-06:/ # chmod –R 777 /hana/data2/SID
    • For a multiple-host system, create mount points and set the permissions on all worker and standby hosts.
      The following example commands are for a 2-plus-1 multiple-host HANA system.
      • First worker host:
        sapcc-hana-tst-06:~ # mkdir -p /hana/data2/SID/mnt00001
        sapcc-hana-tst-06:~ # mkdir -p /hana/data2/SID/mnt00002
        sapcc-hana-tst-06:~ # chmod -R 777 /hana/data2/SID
      • Second worker host:
        sapcc-hana-tst-07:~ # mkdir -p /hana/data2/SID/mnt00001
        sapcc-hana-tst-07:~ # mkdir -p /hana/data2/SID/mnt00002
        sapcc-hana-tst-07:~ # chmod -R 777 /hana/data2/SID
      • Standby host:
  2. Add the additional file systems to the /etc/fstab configuration file on all hosts.
    See the following example for a single-host system using NFSv4.1:
    <storage-vif-data02>:/SID_data2_mnt00001 /hana/data2/SID/mnt00001 nfs rw, vers=4minorversion=1,hard,timeo=600,rsize=1048576,wsize=1048576,bg,noatime,lock 0 0
    Use a different storage virtual interface for connecting each data volume to ensure that you are using different TCP sessions for each volume
  3. Mount the file systems by running the mount –a command.
Adding an additional data volume partition
Execute the following SQL statement against the tenant database to add an additional data volume partition to your tenant database. Use the path to additional volumes:
ALTER SYSTEM ALTER DATAVOLUME ADD PARTITION PATH '/hana/data2/SID/';
Error: Missing Graphic Image
