Step-by-step deployment procedure
Contributors sufianNetApp acao8888 netapp-dorianh Download PDF of this page
CLI deployment Oracle 19c Database
This section covers the steps required to prepare and deploy Oracle19c Database with the CLI. Make sure that you have reviewed the Getting Started and Requirements section and prepared your environment accordingly.
Download Oracle19c repo
1. From your ansible controller, run the following command:
git clone https://github.com/NetApp-Automation/na_oracle19c_deploy.git
2. After downloading the repository, change directories to na_oracle19c_deploy .
Edit the hosts file
Complete the following before deployment:
  1. Edit your hosts file na_oracle19c_deploy directory.
  2. Under [ontap], change the IP address to your cluster management IP.
  3. Under the [oracle] group, add the oracle hosts names. The host name must be resolved to its IP address either through DNS or the hosts file, or it must be specified in the host.
  4. After you have completed these steps, save any changes.
The following example depicts a host file:
#ONTAP Host
[ontap]
10.61.184.183
#Oracle hosts
[oracle]
rtpora01
rtpora02
This example executes the playbook and deploys oracle 19c on two oracle DB servers concurrently. You can also test with just one DB server. In that case, you only need to configure one host variable file.
The playbook executes the same way regardless of how many Oracle hosts and databases you deploy.
Edit the host_name.yml file under host_vars
Each Oracle host has its host variable file identified by its host name that contains host-specific variables. You can specify any name for your host. Edit and copy the host_vars from the Host VARS Config section and paste it into your desired host_name.yml file.
The items in blue must be changed to match your environment.
Host VARS Config
###################################################################### ############## Host Variables Configuration ############## ###################################################################### # Add your Oracle Host ansible_host: 10.61.180.15 # Oracle db log archive mode: true - ARCHIVELOG or false - NOARCHIVELOG log_archive_mode: true # Number of pluggable databases per container instance identified by sid. Pdb_name specifies the prefix for container database naming in this case cdb2_pdb1, cdb2_pdb2, cdb2_pdb3 oracle_sid: cdb2 pdb_num: 3 pdb_name: "{{ oracle_sid }}_pdb" # CDB listener port, use different listener port for additional CDB on same host listener_port: 1523 # CDB is created with SGA at 75% of memory_limit, MB. Consider how many databases to be hosted on the node and how much ram to be allocated to each DB. The grand total SGA should not exceed 75% available RAM on node. memory_limit: 5464 # Set "em_configuration: DBEXPRESS" to install enterprise manager express and choose a unique port from 5500 to 5599 for each sid on the host. # Leave them black if em express is not installed. em_configuration: DBEXPRESS em_express_port: 5501 # "{{groups.oracle[0]}}" represents first Oracle DB server as defined in Oracle hosts group [oracle]. For concurrent multiple Oracle DB servers deployment, [0] will be incremented for each additional DB server. For example, "{{groups.oracle[1]}}" represents DB server 2, "{{groups.oracle[2]}}" represents DB server 3 ... As a good practice and the default, minimum three volumes is allocated to a DB server with corresponding /u01, /u02, /u03 mount points, which store oracle binary, oracle data, and oracle recovery files respectively. Additional volumes can be added by click on "More NFS volumes" but the number of volumes allocated to a DB server must match with what is defined in global vars file by volumes_nfs parameter, which dictates how many volumes are to be created for each DB server. host_datastores_nfs: - {vol_name: "{{groups.oracle[0]}}_u01", aggr_name: aggr01_node01, lif: 172.21.94.200, size: 25} - {vol_name: "{{groups.oracle[0]}}_u02", aggr_name: aggr01_node01, lif: 172.21.94.200, size: 25} - {vol_name: "{{groups.oracle[0]}}_u03", aggr_name: aggr01_node01, lif: 172.21.94.200, size: 25} More NFS volumes
Enter NFS volumes' details
Edit the vars.yml file
The vars.yml file consolidates all environment-specific variables (ONTAP, Linux, or Oracle) for Oracle deployment.
  • Edit and copy the variables from the VARS section and paste these variables into your vars.yml file.
VARS
####################################################################### ###### Oracle 19c deployment global user configuration variables ###### ###### Consolidate all variables from ontap, linux and oracle ###### ####################################################################### ########################################### ### Ontap env specific config variables ### ########################################### #Inventory group name #Default inventory group name - 'ontap' #Change only if you are changing the group name either in inventory/hosts file or in inventory groups in case of AWX/Tower hosts_group: ontap #CA_signed_certificates (ONLY CHANGE to 'true' IF YOU ARE USING CA SIGNED CERTIFICATES) ca_signed_certs: false #Names of the Nodes in the ONTAP Cluster nodes: - AFF-01 - AFF-02 #Storage VLANs #Add additional rows for vlans as necessary storage_vlans: - {vlan_id: "203", name: "infra_NFS", protocol: "NFS"} More Storage VLANs
Enter Storage VLANs details
#Details of the Data Aggregates that need to be created #If Aggregate creation takes longer, subsequent tasks of creating volumes may fail. #There should be enough disks already zeroed in the cluster, otherwise aggregate create will zero the disks and will take long time data_aggregates: - {aggr_name: aggr01_node01} - {aggr_name: aggr01_node02} #SVM name svm_name: ora_svm # SVM Management LIF Details svm_mgmt_details: - {address: 172.21.91.100, netmask: 255.255.255.0, home_port: e0M} # NFS storage parameters when data_protocol set to NFS. Volume named after Oracle hosts name identified by mount point as follow for oracle DB server 1. Each mount point dedicates to a particular Oracle files: u01 - Oracle binary, u02 - Oracle data, u03 - Oracle redo. Add additional volumes by click on "More NFS volumes" and also add the volumes list to corresponding host_vars as host_datastores_nfs variable. For multiple DB server deployment, additional volumes sets needs to be added for additional DB server. Input variable "{{groups.oracle[1]}}_u01", "{{groups.oracle[1]}}_u02", and "{{groups.oracle[1]}}_u03" as vol_name for second DB server. Place volumes for multiple DB servers alternatingly between controllers for balanced IO performance, e.g. DB server 1 on controller node1, DB server 2 on controller node2 etc. Make sure match lif address with controller node. volumes_nfs: - {vol_name: "{{groups.oracle[0]}}_u01", aggr_name: aggr01_node01, lif: 172.21.94.200, size: 25} - {vol_name: "{{groups.oracle[0]}}_u02", aggr_name: aggr01_node01, lif: 172.21.94.200, size: 25} - {vol_name: "{{groups.oracle[0]}}_u03", aggr_name: aggr01_node01, lif: 172.21.94.200, size: 25} More NFS volumes
#NFS LIFs IP address and netmask nfs_lifs_details: - address: 172.21.94.200 #for node-1 netmask: 255.255.255.0 - address: 172.21.94.201 #for node-2 netmask: 255.255.255.0 #NFS client match client_match: 172.21.94.0/24 ########################################### ### Linux env specific config variables ### ########################################### #NFS Mount points for Oracle DB volumes mount_points: - /u01 - /u02 - /u03 # Up to 75% of node memory size divided by 2mb. Consider how many databases to be hosted on the node and how much ram to be allocated to each DB. # Leave it blank if hugepage is not configured on the host. hugepages_nr: 1234 # RedHat subscription username and password redhat_sub_username: xxx redhat_sub_password: xxx #################################################### ### DB env specific install and config variables ### #################################################### db_domain: your.domain.com # Set initial password for all required Oracle passwords. Change them after installation. initial_pwd_all: netapp123
Run the playbook
After completing the required environment prerequisites and copying the variables into vars.yml and your_host.yml, you are now ready to deploy the playbooks.
<username> must be changed to match your environment.
1. Run the ONTAP playbook by passing the correct tags and ONTAP cluster username. Fill the password for ONTAP cluster, and vsadmin when prompted.
ansible-playbook -i hosts all_playbook.yml -u username -k -K -t ontap_config -e @vars/vars.yml
2. Run the Linux playbook to execute Linux portion of deployment. Input for admin ssh password as well as sudo password.
ansible-playbook -i hosts all_playbook.yml -u username -k -K -t linux_config -e @vars/vars.yml
3. Run the Oracle playbook to execute Oracle portion of deployment. Input for admin ssh password as well as sudo password.
ansible-playbook -i hosts all_playbook.yml -u username -k -K -t oracle_config -e @vars/vars.yml
Deploy Additional Database on Same Oracle Host
The Oracle portion of the playbook creates a single Oracle container database on an Oracle server per execution. To create additional container database on the same server, complete the following steps:
  1. Revise the host_vars variables.
    1. Go back to step 3 - Edit the host_name.yml file under host_vars.
    2. Change the Oracle SID to a different naming string.
    3. Change the listener port to different number.
    4. Change the EM Express port to a different number if you have installed EM Express.
    5. Copy and paste the revised host variables to the Oracle host variable file under host_vars.
  2. Execute the playbook with the oracle_config tag as shown above in Run the playbook.
Validate Oracle installation
1. Log in to Oracle server as oracle user and execute the following commands:
ps -ef | grep ora
This will list oracle processes if installation completed as expected and oracle DB started
2. Log in to the database to check the db configuration settings and the PDBs created with the following command sets.
sqlplus / as sysdba
[oracle@localhost ~]$ sqlplus / as sysdba
SQL*Plus: Release 19.0.0.0.0 - Production on Thu May 6 12:52:51 2021
Version 19.8.0.0.0
Copyright (c) 1982, 2019, Oracle. All rights reserved.
Connected to:
Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production
Version 19.8.0.0.0
SQL>
select name, log_mode from v$database;
SQL> select name, log_mode from v$database;
NAME LOG_MODE
CDB2 ARCHIVELOG
show pdbs;
SQL> show pdbs
    CON_ID CON_NAME                       OPEN MODE  RESTRICTED
         2 PDB$SEED                       READ ONLY  NO
         3 CDB2_PDB1                      READ WRITE NO
         4 CDB2_PDB2                      READ WRITE NO
         5 CDB2_PDB3                      READ WRITE NO
col svrname form a30
col dirname form a30
select svrname, dirname, nfsversion from v$dnfs_servers;
SQL> col svrname form a30
SQL> col dirname form a30
SQL> select svrname, dirname, nfsversion from v$dnfs_servers;
SVRNAME DIRNAME NFSVERSION
172.21.126.200 /rhelora03_u02 NFSv3.0
172.21.126.200 /rhelora03_u03 NFSv3.0
172.21.126.200 /rhelora03_u01 NFSv3.0
This confirms that dNFS is working properly.
3. Connect to database via listener to check hte Oracle listener configuration with the following command. Change to the appropriate listener port and database service name.
sqlplus system@//localhost:1523/cdb2_pdb1.cie.netapp.com
[oracle@localhost ~]$ sqlplus system@//localhost:1523/cdb2_pdb1.cie.netapp.com
SQL*Plus: Release 19.0.0.0.0 - Production on Thu May 6 13:19:57 2021
Version 19.8.0.0.0
Enter password:
Last Successful login time: Wed May 05 2021 17:11:11 -04:00
Connected to:
Version 19.8.0.0.0
SQL> show user
USER is "SYSTEM"
SQL> show con_name
CON_NAME
CDB2_PDB1
This confirms that Oracle listener is working properly.
Where to go for help?
If you need help with the toolkit, please join the NetApp Solution Automation community support slack channel and look for the solution-automation channel to post your questions or inquires.
