vSphere VMFS Datastore - NVMe/FC with ONTAP
Contributors jpowellgit sureshthoppay Download PDF of this page
About this task
This section covers the creation of a VMFS datastore with ONTAP storage using NVMe/FC.
For automated provisioning, use one of these scripts: [PowerShell], [Ansible], or [Terraform].
What you need
  • Basic skills needed to manage a vSphere environment and ONTAP.
  • Basic understanding of NVMe/FC.
  • An ONTAP Storage System (FAS/AFF/CVO/ONTAP Select/ASA) running ONTAP 9.8 or later
  • ONTAP credentials (SVM name, userID, and password)
  • ONTAP WWPN for host, target, and SVMs and LUN information
  • A completed FC configuration worksheet
  • vCenter Server
  • vSphere host(s) information (vSphere 7.0 or later)
  • Fabric switch(es)
    • With ONTAP FC data ports and vSphere hosts connected.
    • With the N_port ID virtualization (NPIV) feature enabled.
    • Create a single initiator target zone.
    • Create one zone for each initiator (single initiator zone).
    • For each zone, include a target that is the ONTAP FC logical interface (WWPN) for the SVMs. There should be at least two logical interfaces per node per SVM. DO not use the WWPN of physical ports.
Provision VMFS datastore
ONTAP tasks
  1. Verify the ONTAP license for FCP.
    Use the system license show command and check if NVMe_oF is listed.
    Use license add -license-code <license code> to add a license.
  2. Verify that NVMe protocol is enabled on the SVM.
  3. Verify that NVMe/FC Logical Interfaces are available on the SVMs.
    1. Use Network Interface show to verify the FCP adapter.
    2. When an SVM is created with the GUI, logical interfaces are as part of that process.
    3. To rename the network interface, use the command Network Interface modify.
  4. Create NVMe namespace and subsystem
VMware vSphere Tasks
  1. Verify that HBA drivers are installed. VMware supported HBAs have the drivers deployed out of the box and should be visible at Storage Adapter Information
  2. Perform vSphere Host NVMe driver installatioln and validation tasks
  3. Create VMFS Datastore
