Validation Results
Download PDF of this page
We used the iPerf tool for testing network throughput, and the baseline expectation was that the test systems should achieve throughput within 10% of the maximum line rate. Test results for different virtual switches is indicated in the following table.
For storage IOPS subsystem measurement, we used the IOmeter tool. The baseline expectation was that the test systems should achieve read/write throughput within 10% of the maximum. Test results for different hypervisors is indicated in the following table.
We considered the following scenarios for the network line rate and storage IOPS testing:
VMware
VMs on a NetApp HCI datastore (with and without micro-segmentation)
VMs on a NetApp ONTAP datastore
VMs on a NetApp ONTAP Select datastore
Red Hat Virtualization
KVM (RHEL)
Miscellaneous
One VM on RHV with a NetApp HCI datastore and one VM on VMware vSphere with a NetApp ONTAP datastore.
Hypervisor | Virtual Switch | iPerf | IOmeter | Micro-segmentation |
VMware |
VDS |
Pass |
Pass |
Pass |
RHV |
Linux Bridge |
Pass |
Pass |
N/A |
RHEL-KVM |
Open vSwitch |
Pass |
Pass |
N/A |
