1. Configure Management Switches: NetApp HCI with RHV
Contributors kevin-hoke netapp-dorianh Download PDF of this page
Cisco Nexus 3048 switches are used in this deployment procedure to provide 1Gbps connectivity for in and out-of-band management of the compute and storage nodes. These steps begin after the switches have been racked, powered, and put through the initial setup process. To configure the switches to provide management connectivity to the infrastructure, complete the following steps:
Enable Advanced Features for Cisco Nexus
Run the following commands on each Cisco Nexus 3048 switch to configure advanced features:
  1. Enter configuration mode.
    Switch-01# configure terminal
  2. Enable VLAN functionality.
    Switch-01(config)# feature interface-vlan
  3. Enable LACP.
    Switch-01(config)# feature lacp
  4. Enable virtual port channels (vPCs).
    Switch-01(config)# feature vpc
  5. Set the global port-channel load-balancing configuration.
    Switch-01(config)# port-channel load-balance src-dst ip-l4port
  6. Perform global spanning-tree configuration.
Switch-01(config)# spanning-tree port type network default
Switch-01(config)# spanning-tree port type edge bpduguard default
Configure Ports on the Switch for In-Band Management
  1. Run the following commands to create VLANs for management purposes:
    Switch-01(config)# vlan 2
    Switch-01(config-vlan)# Name Native_VLAN
    Switch-01(config-vlan)# vlan 16
    Switch-01(config-vlan)# Name OOB_Network
    Switch-01(config-vlan)# vlan 1172
    Switch-01(config-vlan)# Name MGMT_Network
    Switch-01(config-vlan)# exit
  2. Configure the ports ETH1/29-32 as VLAN trunk ports that connect to management interfaces on each HCI storage node.
Switch-01(config)# int eth 1/29
Switch-01(config-if)# description HCI-STG-01 PortA
Switch-01(config-if)# switchport mode trunk
Switch-01(config-if)# switchport trunk native vlan 2
Switch-01(config-if)# switchport trunk allowed vlan 1172
Switch-01(config-if)# spanning tree port type edge trunk
Switch-01(config-if)# int eth 1/30
Switch-01(config-if)# description HCI-STG-02 PortA
Switch-01(config-if)# int eth 1/31
Switch-01(config-if)# description HCI-STG-03 PortA
Switch-01(config-if)# int eth 1/32
Switch-01(config-if)# description HCI-STG-04 PortA
Switch-01(config-if)# exit
Configure Ports on the Switch for Out-of-Band Management
Run the following commands to configure the ports for cabling the IPMI interfaces on each HCI node.
Switch-01(config)# int eth 1/13
Switch-01(config-if)# description HCI-CMP-01 IPMI
Switch-01(config-if)# switchport mode access
Switch-01(config-if)# switchport access vlan 16
Switch-01(config-if)# spanning-tree port type edge
Switch-01(config-if)# int eth 1/14
Switch-01(config-if)# description HCI-STG-01 IPMI
Switch-01(config-if)# int eth 1/15
Switch-01(config-if)# description HCI-STG-03 IPMI
In the validated configuration, we cabled odd-node IPMI interfaces to Switch-01 and even-node IPMI interfaces to Switch-02.
Create a vPC Domain to Ensure Fault Tolerance
  1. Activate the ports used for the vPC peer-link between the two switches.
    Switch-01(config-if)# description vPC peer-link Switch-02 1/1
    Switch-01(config-if)# int eth 1/2
    Switch-01(config-if)# description vPC peer-link Switch-02 1/2
  2. Perform the vPC global configuration.
Switch-01(config)# vpc domain 1
Switch-01(config-vpc-domain)# role priority 10
Switch-01(config-vpc-domain)# peer-keepalive destination <switch-02_mgmt_address> source <switch-01_mgmt_address> vrf managment
Switch-01(config-vpc-domain)# peer-gateway
Switch-01(config-vpc-domain)# auto recovery
Switch-01(config-vpc-domain)# ip arp synchronize
Switch-01(config-vpc-domain)# int eth 1/1-2
Switch-01(config-vpc-domain)# channel-group 10 mode active
Switch-01(config-vpc-domain)# int Po10
Switch-01(config-if)# switchport trunk allowed vlan 16, 1172
Switch-01(config-if)# spanning-tree port type network
Switch-01(config-if)# vpc peer-link
