Go to the docs for the latest release.
Cloud Storage Automation
The Cloud Storage Automation Report analyzes your cloud storage to show you savings opportunities, data protection enhancements, and operations that can optimize the storage associated with your AWS account. This is a beta feature.
Sample report
The following image shows a sample report:
In some cases, the report enables you to take immediate action. For example, when you view the list of unattached EBS volumes or unassociated EBS snapshots, you can delete them right from Cloud Manager:
What happens when you enable the report
Cloud Manager collects information about the EC2 instances, EBS volumes, and EBS snapshots associated with your AWS account, in the region where Cloud Manager resides. AWS resources used for ONTAP Cloud systems are excluded. There is no performance impact on AWS resources.
When Cloud Manager collects the information, it identifies improvement opportunities by using EBS snapshots to calculate used capacity and daily usage growth predictions.
The report runs once a week, but you can initiate an immediate data collection at any time.
Required permissions
The AWS permissions required for Cloud Storage Automation are included in the Cloud Manager IAM policy. If you set up permissions correctly, then there is nothing further to do. See Granting AWS permissions for details.
