Go to the docs for the latest release.
Storage management
Cloud Manager provides simplified and advanced management of ONTAP Cloud storage.
Storage provisioning
Cloud Manager makes storage provisioning for ONTAP Cloud easy by purchasing disks and managing aggregates for you. You simply need to create volumes. You can use an advanced allocation option to provision aggregates yourself, if desired.
Simplified provisioning
Aggregates provide cloud storage to ONTAP Cloud volumes. Cloud Manager creates aggregates for you when you launch an instance, and when you provision additional volumes.
When you create a volume, Cloud Manager does one of three things:
It places the volume on an existing aggregate that has sufficient free space.
It places the volume on an existing aggregate by purchasing more disks for that aggregate.
It purchases disks for a new aggregate and places the volume on that aggregate.
Cloud Manager determines where to place a new volume by looking at several factors: an aggregate’s maximum size, whether thin provisioning is enabled, and free space thresholds for aggregates.
The Cloud Manager Admin can modify free space thresholds from the Settings page. |
Disk size selection for aggregates in AWS
When Cloud Manager creates new aggregates for ONTAP Cloud systems in AWS, it gradually increases the disk size in an aggregate, as the number of aggregates in the system increases. Cloud Manager does this to ensure that you can utilize the system’s maximum capacity before it reaches the maximum number of data disks allowed by AWS.
For example, Cloud Manager might choose the following disk sizes for aggregates in an ONTAP Cloud Premium or BYOL system:
Aggregate number | Disk size | Max aggregate capacity |
1 |
500 MB |
3 TB |
4 |
1 TB |
6 TB |
6 |
2 TB |
12 TB |
You can choose the disk size yourself by using the advanced allocation option.
Advanced allocation
Rather than let Cloud Manager manage aggregates for you, you can do it yourself. From the Advanced allocation page, you can create new aggregates that include a specific number of disks, add disks to an existing aggregate, and create volumes in specific aggregates.
Capacity management
The Cloud Manager Admin can choose whether Cloud Manager notifies you of storage capacity decisions or whether Cloud Manager automatically manages capacity requirements for you. It might help for you to understand how these modes work.
Automatic capacity management
If the Cloud Manager Admin set the Capacity Management Mode to automatic, Cloud Manager automatically purchases new disks for ONTAP Cloud instances when more capacity is needed, deletes unused collections of disks (aggregates), and moves volumes between aggregates, as needed.
The following examples illustrate how this mode works:
If an aggregate with 5 or fewer EBS disks reaches the capacity threshold, Cloud Manager automatically purchases new disks for that aggregate so volumes can continue to grow.
If an aggregate with 12 Azure disks reaches the capacity threshold, Cloud Manager automatically moves a volume from that aggregate to an aggregate with available capacity or to a new aggregate.
Note that free space is now available on the original aggregate. Existing volumes or new volumes can use that space. The space cannot be returned to AWS or Azure in this scenario.
If an aggregate contains no volumes for more than 12 hours, Cloud Manager deletes it.
Manual capacity management
If the Cloud Manager Admin set the Capacity Management Mode to manual, Cloud Manager displays Action Required messages when capacity decisions must be made. The same examples described in the automatic mode apply to the manual mode, but it is up to you to accept the actions.
Storage isolation using tenants
Cloud Manager enables you to provision and manage storage in isolated groups called tenants. You need to decide how to organize Cloud Manager users and their working environments across tenants.
Working environments
Cloud Manager represents storage systems as working environments. A working environment is any of the following:
A single ONTAP Cloud system or an HA pair
An on-premises ONTAP cluster in your network
An ONTAP cluster in a NetApp Private Storage configuration
The following image shows an ONTAP Cloud working environment:
Tenants
A tenant isolates working environments in groups. You create one or more working environments within a tenant. The following image shows three tenants defined in Cloud Manager:
User management of tenants and working environments
The tenants and working environments that Cloud Manager users can manage depend on user role and assignments. The three distinct user roles are as follows:
- Cloud Manager Admin
Administers the product and can access all tenants and working environments.
- Tenant Admin
Administers a single tenant. Can create and manage all working environments and users in the tenant.
- Working Environment Admin
Can create and manage one or more working environments in a tenant.
Example of how you can create tenants and users
If your organization has departments that operate independently, it is best to have a tenant for each department.
For example, you might create three tenants for three separate departments. You would then create a Tenant Admin for each tenant. Within each tenant would be one or more Working Environment Admins who manage working environments. The following image depicts this scenario:
Why you should link a tenant to your NetApp Support Site account
Cloud Manager prompts you to enter NetApp Support Site credentials for a tenant because it uses the credentials to manage licenses for ONTAP Cloud BYOL systems, to register pay-as-you-go instances for support, and to upgrade ONTAP Cloud software.
License management for BYOL systems
Linking a tenant to your NetApp Support Site account is required if you plan to launch BYOL instances in a tenant. Cloud Manager uses your account to obtain license files from NetApp and installs them on ONTAP Cloud BYOL systems. The NetApp Support Site account must be authorized to access the serial numbers of the ONTAP Cloud BYOL systems in the tenant.
Support registration for pay-as-you-go instances
While entering an account is not required to launch pay-as-you-go instances, it is highly recommended because Cloud Manager automatically registers new pay-as-you-go instances for support.
Software upgrades
Entering a NetApp Support Site account also enables ONTAP Cloud software upgrades directly from Cloud Manager for both pay-as-you-go and BYOL instances.
NetApp Support Site account requirements
Each NetApp Support Site account that you link to a tenant must be a NetApp customer-level account (not a guest or temp account). For the AWS GovCloud (US) region, the NetApp Support Site account must be a secure account. If you do not have an account, you can create one from the NetApp Support Site.
Simplified storage management using the Volume View
Cloud Manager provides a separate management view called the Volume View, which further simplifies storage management in AWS.
The Volume View enables you to simply specify the NFS volumes that you need in AWS and then Cloud Manager handles the rest: it deploys ONTAP Cloud systems as needed and it makes capacity allocation decisions as volumes grow. This view gives you the benefits of enterprise-class storage in the cloud with very little storage management.
The following image shows how you interact with Cloud Manager in the Volume View:
You create NFS volumes.
Cloud Manager launches ONTAP Cloud instances in AWS for new volumes or it creates volumes on existing instances. It also purchases physical EBS storage for the volumes.
You make the volumes available to your hosts and applications.
Cloud Manager makes capacity allocation decisions as your volumes grow.
This means that you simply need to interact with volumes (the image on the left), while Cloud Manager interacts with the storage system and its underlying storage (the image on the right).
Allocation of cloud resources for the initial volume
When you create your first volume, Cloud Manager launches an ONTAP Cloud instance or an ONTAP Cloud HA pair in AWS and purchases Amazon EBS storage for the volume:
The size of the initial volume determines the EC2 instance type and the number of EBS disks.
Cloud Manager launches an ONTAP Cloud Explore or Standard instance, depending on the initial volume size. As the volumes grow, Cloud Manager might prompt you to make an AWS instance change which means it needs to upgrade the instance’s license to Standard or Premium. Upgrading increases the EBS raw capacity limit, which allows your volumes to grow. |
Cloud Manager does not launch ONTAP Cloud BYOL instances in the Volume View. You should use Cloud Manager in the Storage System View if you purchased an ONTAP Cloud license. |
Allocation of cloud resources for additional volumes
When you create additional volumes, Cloud Manager creates the volumes on existing ONTAP Cloud instances or on new ONTAP Cloud instances. Cloud Manager can create a volume on an existing instance if the instance’s AWS location and disk type match the requested volume, and if there is enough space.
NetApp storage efficiency features and storage costs
Cloud Manager automatically enables NetApp storage efficiency features on all volumes. These efficiencies can reduce the total amount of storage that you need. You might see a difference between your allocated capacity and the purchased AWS capacity, which can result in storage cost savings.
Capacity allocation decisions that Cloud Manager automatically handles
Cloud Manager purchases additional EBS disks as capacity thresholds are exceeded. This happens as your volumes grow.
Cloud Manager deletes unused sets of EBS disks if the disks contain no volumes for 12 hours.
Cloud Manager moves volumes between sets of disks to avoid capacity issues.
In some cases, this requires purchasing additional EBS disks. It also frees space on the original set of disks for new and existing volumes.
