Go to the docs for the latest release.
IBM Cloud networking requirements
If you want to install Cloud Manager in the IBM Cloud, then the environment must meet a few requirements.
While you can install Cloud Manager in the IBM Cloud, ONTAP Cloud is not supported in the IBM Cloud. |
- Outbound internet access
Cloud Manager needs outbound internet access to communicate with AWS and Azure services when deploying ONTAP Cloud, to access software images for upgrades, and to enable technical support from NetApp.
For details about the specific endpoints, see AWS networking requirements and Azure networking requirements.
- Connection between Cloud Manager and ONTAP Cloud subnets
Cloud Manager requires a network connection to the AWS VPCs and Azure VNets in which you want to deploy ONTAP Cloud systems.
- Connection to the Cloud Manager web console
Users must access Cloud Manager from a web browser. A web browser must have connections to the following endpoints:
Endpoint Purpose The Cloud Manager host
You must enter the host’s IP address from a web browser to load the Cloud Manager console.
The easiest way to provide access is by allocating a public IP address. However, if you want to use a private IP address instead, users can access the console through either of the following:
A jump host that has a connection to Cloud Manager
A host in your network that has a VPN connection to the private IP address
https://netapp-cloud-account.auth0.com
Your web browser connects to this endpoint for centralized user authentication through NetApp Cloud Central.
