Go to the docs for the latest release.
Provisioning storage
You can provision additional NFS and CIFS storage for your ONTAP Cloud systems from Cloud Manager by managing volumes and aggregates. If you need to create iSCSI storage, you should do so from System Manager.
Provisioning volumes
If you need more storage after you launch an ONTAP Cloud system, you can provision new NFS and CIFS volumes from Cloud Manager.
If you want to use CIFS in AWS, you must have set up DNS and Active Directory. For details, see AWS networking requirements.
On the Working Environments page, double-click the name of the ONTAP Cloud system on which you want to provision volumes.
Create a new volume on any aggregate or on a specific aggregate:
Action Steps Create a new volume and let Cloud Manager choose the containing aggregate
Click Add New Volume.
Create a new volume on a specific aggregate
Click the menu icon, and then click Advanced > Advanced allocation.
Click the menu for an aggregate.
Click Create volume.
Enter details for the new volume, and then click Continue.
Some of the fields in this page are self-explanatory. The following table describes fields for which you might need guidance:
Field Description Size
The maximum size that you can enter largely depends on whether you enable thin provisioning, which enables you to create a volume that is bigger than the physical storage currently available to it.
Access control (for NFS only)
An export policy defines the clients in the subnet that can access the volume. By default, Cloud Manager enters a value that provides access to all instances in the subnet.
Permissions and Users / Groups (for CIFS only)
These fields enable you to control the level of access to a share for users and groups (also called access control lists or ACLs). You can specify local or domain Windows users or groups, or UNIX users or groups. If you specify a domain Windows user name, you must include the user’s domain using the format domain\username.
Volume Protection
A Snapshot copy policy specifies the frequency and number of automatically created NetApp Snapshot copies. A NetApp Snapshot copy is a point-in-time file system image that has no performance impact and requires minimal storage. You can choose the default policy or none. You might choose none for transient data: for example, tempdb for Microsoft SQL Server.
If you chose the CIFS protocol and the CIFS server has not been set up, specify details for the server in the Create a CIFS Server dialog box, and then click Save and continue:
Field Description DNS Primary and Secondary IP Address
The IP addresses of the DNS servers that provide name resolution for the CIFS server.
The listed DNS servers must contain the service location records (SRV) needed to locate the Active Directory LDAP servers and domain controllers for the domain that the CIFS server will join.Active Directory Domain to join
The FQDN of the Active Directory (AD) domain that you want the CIFS server to join.
Credentials authorized to join the domain
The name and password of a Windows account with sufficient privileges to add computers to the specified Organizational Unit (OU) within the AD domain.
CIFS server NetBIOS name
A CIFS server name that is unique in the AD domain.
Organizational Unit
The organizational unit within the AD domain to associate with the CIFS server. The default is CN=Computers.
DNS Domain
The DNS domain for the ONTAP Cloud storage virtual machine (SVM). In most cases, the domain is the same as the AD domain.
On the Usage Profile & Tiering page, choose a usage profile and disk type, and then click Go.
For details about usage profiles, see Choosing a volume usage profile.
When prompted, click Approve.
ONTAP Cloud provisions the volume.
If you provisioned a CIFS share, give users or groups permissions to the files and folders and verify that those users can access the share and create a file.
If you want to apply quotas to volumes, you must use System Manager or the CLI. Quotas enable you to restrict or track the disk space and number of files used by a user, group, or qtree.
Provisioning volumes on the second node in an HA configuration
By default, Cloud Manager creates volumes on the first node in an HA configuration. If you need an active-active configuration, in which both nodes serve data to clients, you must create aggregates and volumes on the second node.
On the Working Environments page, double-click the name of the ONTAP Cloud working environment on which you want to manage aggregates.
Click the menu icon and then click Advanced > Advanced allocation.
Click Add Aggregate and then create the aggregate.
For Home Node, choose the second node in the HA pair.
After Cloud Manager creates the aggregate, select it and then click Create volume.
Enter details for the new volume, and then click Create.
You can create additional volumes on this aggregate if required.
When you mount the volume to clients, you must use the floating IP address of the node on which the volume resides. |
Creating aggregates
You can create aggregates yourself or let Cloud Manager do it for you when it creates volumes. The benefit of creating aggregates yourself is that you can choose the underlying EBS disk size, which enables you to size your aggregate for the capacity or the performance that you need.
On the Working Environments page, double-click the name of the ONTAP Cloud instance on which you want to manage aggregates.
Click Add Aggregate and then specify details for the aggregate.
For help with disk type and disk size, see Planning your configuration.
Click Go, and then click Approve and Purchase.
Provisioning iSCSI LUNs
If you want to create iSCSI LUNs, you need to do so from System Manager.
The Host Utilities must be installed and set up on the hosts that will connect to the LUN.
You must have recorded the iSCSI initiator name from the host. You need to supply this name when you create an igroup for the LUN.
Before you create volumes in System Manager, you must ensure that you have an aggregate with sufficient space. You need to create aggregates in Cloud Manager. For details, see Creating aggregates.
These steps describe how to use System Manager for ONTAP Cloud 9.3 and later.
Click Storage > LUNs.
Click Create and follow the prompts to create the LUN.
Connect to the LUN from your hosts.
For instructions, see the Host Utilities documentation for your operating system.
