Request doc changesEdit this pageLearn how to contribute
ON THIS PAGE
    • Product and Solutions
    • Support and Training
    • Cloud Central
    • Community
    • Blog
    • Customer Stories
    • Contact
    • Contact
    Menu bars
    netapp-mark netapp-logo
    Available PDFs
    • PDF of this doc site
      • Release notes
        • Cloud Manager
          • PDF of this page
      • Concepts
      • Getting started
        • Detailed networking requirements
        • Additional deployment options
        • Additional ways to provide permissions
      • Deploying Cloud Volumes ONTAP
      • Provisioning storage
        • Provisioning NFS volumes from the Volume View
      • Managing data across a hybrid cloud
      • Administering Cloud Volumes ONTAP
      • Administering Cloud Manager
      • Reference
    Creating your file...
    Your file is ready
    • Cloud Manager 3.5 docs
    • Release notes
      • Cloud Manager
        • What's new
        • Known issues
        • Known limitations
      • Cloud Volumes ONTAP
    • Concepts
      • Product overview
      • NetApp Cloud Central
      • Storage
      • Storage management
      • High-availability pairs
      • Security
      • WORM storage
      • Licensing
      • Performance
      • Cloud Storage Automation
    • Getting started
      • Deployment overview
      • Getting started in AWS
      • Getting started in Azure
      • Setting up Cloud Manager
        • Requirements for Cloud Manager
        • Requirements for Cloud Volumes ONTAP in AWS
        • Requirements for Cloud Volumes ONTAP in Azure
        • Cloud Manager host requirements
        • Installing Cloud Manager on a Linux host
        • Deploying Cloud Manager from the AWS Marketplace
        • Deploying Cloud Manager from the Azure Marketplace
        • Intalling Cloud Manager in Azure Gov
        • Installing Cloud Manager in Azure Germany
        • Granting AWS permissions when Cloud Manager is not launched from Cloud Central
        • Granting Azure permissions using a service principal and credentials
        • Changing to a Managed Service Identity
      • Before you begin
      • Logging in to Cloud Manager
      • Planning your configuration
      • Launching Cloud Volumes ONTAP in AWS
      • Launching Cloud Volumes ONTAP in Azure
      • Registering pay-as-you-go systems
      • Setting up Cloud Volumes ONTAP
      • Creating volumes, aggregates, and LUNs
      • Tiering cold data to object storage
      • Managing existing storage
        • Changing to the Volume View
        • Creating and mounting NFS volumes
        • Managing NFS volumes
      • Discovering and managing ONTAP clusters
      • Replicating data to and from the cloud
      • Syncing data to AWS S3
      • Connecting to Cloud Volumes ONTAP
      • Updating Cloud Volumes ONTAP software
      • Modifying Cloud Volumes ONTAP systems
      • Managing the state of Cloud Volumes ONTAP
      • Monitoring AWS costs
      • Adding existing Cloud Volumes ONTAP systems
      • Deleting Cloud Volumes ONTAP systems
      • Updating Cloud Manager
      • Backing up and restoring
      • Removing Cloud Volumes ONTAP working environments
      • Editing user accounts
      • Configuring Cloud Manager to use a proxy server
      • Managing encryption settings
      • Renewing the HTTPS certificate
      • Uninstalling Cloud Manager
    • Reference
      • FAQ for Cloud Central integration
      • Supported configurations for Cloud Volumes ONTAP
      • Supported regions
      • Security group rules for AWS
      • Security group rules for Azure
      • REST APIs
      • Permissions
      • Default configurations
      • User roles
      • Related links
    • Earlier versions
    • docs.netapp.com
    • Cloud Manager 3.5
    This documentation is for a previous release of Cloud Manager.
    Go to the docs for the latest release.
    Known issues
    11/01/2018 Contributors netapp-bcammett
    Known issues identify problems that might prevent you from using this release of the product successfully.
    There are no known issues in this release of Cloud Manager.
    You can find known issues for Cloud Volumes ONTAP in the Cloud Volumes ONTAP Release Notes and for ONTAP software in general in the ONTAP Release Notes.
    • © 2022 NetApp, Inc.
    • Terms of Use
    • Privacy Policy
    • Cookie Policy
    • Cookie Settings
    • Have feedback for our website? Let us know
    • Announcements
    • blog blog@
    • community community@
    • twitter twitter@
    • facebook facebook@
    • linkedin linkedin@
    • youtube youtube@
    • slideshare slideshare@
