Go to the docs for the latest release.
Networking requirements for Cloud Manager
You must set up your networking so that Cloud Manager can deploy Cloud Volumes ONTAP systems in AWS or in Microsoft Azure. The most important step is ensuring outbound internet access to various endpoints.
If your network uses a proxy server for all communication to the internet, Cloud Manager prompts you to specify the proxy during setup. You can also specify the proxy server from the Settings page. Refer to Configuring Cloud Manager to use a proxy server. |
Connection to target networks
Cloud Manager requires a network connection to the AWS VPCs and Azure VNets in which you want to deploy Cloud Volumes ONTAP.
For example, if you install Cloud Manager in your corporate network, then you must set up a VPN connection to the AWS VPC or Azure VNet in which you launch Cloud Volumes ONTAP.
Outbound internet access
Cloud Manager requires outbound internet access to deploy and manage Cloud Volumes ONTAP. Outbound internet access is also required when accessing Cloud Manager from your web browser and when running the Cloud Manager installer on a Linux host.
The following sections identify the specific endpoints.
- Outbound internet access to manage Cloud Volumes ONTAP in AWS
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in AWS:
Endpoints Purpose AWS services (amazonaws.com):
CloudFormation
Elastic Compute Cloud (EC2)
Key Management Service (KMS)
Security Token Service (STS)
Simple Storage Service (S3)
The exact endpoint depends on the region in which you deploy Cloud Volumes ONTAP. Refer to AWS documentation for details.
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in AWS.
api.services.cloud.netapp.com:443
API requests to NetApp Cloud Central.
cloud.support.netapp.com.s3.us-west-1.amazonaws.com
Provides access to software images, manifests, and templates.
cognito-idp.us-east-1.amazonaws.com
cognito-identity.us-east-1.amazonaws.comEnables Cloud Manager to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images.
kinesis.us-east-1.amazonaws.com
Enables NetApp to stream data from audit records.
https://netapp-cloud-account.auth0.com
Communication with NetApp Cloud Central for centralized user authentication.
https://mysupport.netapp.com
Communication with NetApp AutoSupport.
https://support.netapp.com/svcgw
https://support.netapp.com/ServiceGW/entitlementCommunication with NetApp for licensing and support registration.
Various third-party locations, for example:
https://repo1.maven.org/maven2
https://oss.sonatype.org/content/repositories
https://repo.typesafe.org
Third-party locations are subject to change.
During upgrades, Cloud Manager downloads the latest packages for third-party dependencies.
- Outbound internet access to manage Cloud Volumes ONTAP in Azure
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in Microsoft Azure:
Endpoints Purpose https://management.azure.com
https://login.microsoftonline.comEnables Cloud Manager to deploy and manage Cloud Volumes ONTAP in most Azure regions.
https://management.microsoftazure.de
https://login.microsoftonline.deEnables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure Germany regions.
https://management.usgovcloudapi.net
https://login.microsoftonline.comEnables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure US Gov regions.
sts.amazonaws.comEnables Cloud Manager to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images.
- Outbound internet access from your web browser
Users must access Cloud Manager from a web browser. The machine running the web browser must have connections to the following endpoints:
Endpoints Purpose The Cloud Manager host
You must enter the host’s IP address from a web browser to load the Cloud Manager console.
If you deploy Cloud Manager in AWS, the easiest way to provide access is by allocating a public IP address. However, if you want to use a private IP address instead, users can access the console through either of the following:
A jump host in the VPC that has a connection to Cloud Manager
A host in your network that has a VPN connection to the private IP address
https://auth0.com
https://services.cloud.netapp.comYour web browser connects to these endpoints for centralized user authentication through NetApp Cloud Central.
- Outbound internet access to install Cloud Manager on a Linux host
The Cloud Manager installer must access the following URLs during the installation process:
http://dev.mysql.com/get/mysql-community-release-el7-5.noarch.rpm
https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
https://s3.amazonaws.com/aws-cli/awscli-bundle.zip
Ports and security groups
If you deploy Cloud Manager from Cloud Central or from the marketplace images, refer to the following:
If you install Cloud Manager on an existing Linux host, see Cloud Manager host requirements.
