This documentation is for a previous release of Cloud Manager.
Go to the docs for the latest release.
Security group rules for AWS
Contributors netapp-bcammett
Cloud Manager creates AWS security groups that include the inbound and outbound rules that Cloud Manager and Cloud Volumes ONTAP need to operate successfully. You might want to refer to the ports for testing purposes or if you prefer your to use own security groups.
Rules for Cloud Manager
The security group for Cloud Manager requires both inbound and outbound rules.
Inbound rules for Cloud Manager
The source for inbound rules in the predefined security group is 0.0.0.0/0.
Protocol Port Purpose
SSH
22
Provides SSH access to the Cloud Manager host
HTTP
80
Provides HTTP access from client web browsers to the Cloud Manager web console
HTTPS
443
Provides HTTPS access from client web browsers to the Cloud Manager web console
Outbound rules for Cloud Manager
The predefined security group for Cloud Manager opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Manager includes the following outbound rules.
All TCP
All
All outbound traffic
All UDP
All
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Manager.
Note The source IP address is the Cloud Manager host.
Service Protocol Port Destination Purpose
Active Directory
TCP
88
Active Directory forest
Kerberos V authentication
TCP
139
NetBIOS service session
TCP
389
LDAP
TCP
445
Microsoft SMB/CIFS over TCP with NetBIOS framing
TCP
464
Kerberos V change & set password (SET_CHANGE)
TCP
749
Active Directory Kerberos V change & set password (RPCSEC_GSS)
UDP
137
NetBIOS name service
UDP
138
NetBIOS datagram service
UDP
464
Kerberos key administration
API calls and AutoSupport
HTTPS
443
Outbound internet and ONTAP cluster management LIF
API calls to AWS and ONTAP, and sending AutoSupport messages to NetApp
API calls
TCP
3000
API calls to ONTAP
DNS
UDP
53
DNS
Used for DNS resolve by Cloud Manager
Rules for Cloud Volumes ONTAP
The security group for Cloud Volumes ONTAP requires both inbound and outbound rules.
Inbound rules for Cloud Volumes ONTAP
All ICMP
All
Pinging the instance
HTTP
80
HTTP access to the System Manager web console using the IP address of the cluster management LIF
HTTPS
443
HTTPS access to the System Manager web console using the IP address of the cluster management LIF
SSH
22
SSH access to the IP address of the cluster management LIF or a node management LIF
TCP
111
Remote procedure call for NFS
TCP
139
NetBIOS service session for CIFS
TCP
161-162
Simple network management protocol
TCP
445
TCP
635
NFS mount
TCP
749
Kerberos
TCP
2049
NFS server daemon
TCP
3260
iSCSI access through the iSCSI data LIF
TCP
4045
NFS lock daemon
TCP
4046
Network status monitor for NFS
TCP
10000
Backup using NDMP
TCP
11104
Management of intercluster communication sessions for SnapMirror
TCP
11105
SnapMirror data transfer using intercluster LIFs
UDP
111
UDP
161-162
UDP
635
NFS mount
UDP
2049
NFS server daemon
UDP
4045
NFS lock daemon
UDP
4046
UDP
4049
NFS rquotad protocol
Outbound rules for Cloud Volumes ONTAP
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
All ICMP
All
All TCP
All
All UDP
All
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
Note The source is the interface (IP address) on the Cloud Volumes ONTAP system.
Service Protocol Port Source Destination Purpose
Active Directory
TCP
88
Node management LIF
UDP
137
Node management LIF
UDP
138
Node management LIF
TCP
139
Node management LIF
TCP
389
Node management LIF
LDAP
TCP
445
Node management LIF
TCP
464
Node management LIF
UDP
464
Node management LIF
TCP
749
Node management LIF
Kerberos V change & set Password (RPCSEC_GSS)
TCP
88
Data LIF (NFS, CIFS)
UDP
137
UDP
138
TCP
139
TCP
389
LDAP
TCP
445
TCP
464
UDP
464
TCP
749
Cluster
All traffic
All traffic
All LIFs on one node
All LIFs on the other node
Intercluster communications (Cloud Volumes ONTAP HA only)
TCP
3000
Node management LIF
HA mediator
ZAPI calls (Cloud Volumes ONTAP HA only)
ICMP
1
Node management LIF
HA mediator
Keep alive (Cloud Volumes ONTAP HA only)
DHCP
UDP
68
Node management LIF
DHCP
DHCP client for first-time setup
DHCPS
UDP
67
Node management LIF
DHCP
DHCP server
DNS
UDP
53
Node management LIF and data LIF (NFS, CIFS)
DNS
DNS
NDMP
TCP
18600–18699
Node management LIF
Destination servers
NDMP copy
SMTP
TCP
25
Node management LIF
Mail server
SMTP alerts, can be used for AutoSupport
SNMP
TCP
161
Node management LIF
Monitor server
Monitoring by SNMP traps
UDP
161
Node management LIF
Monitor server
TCP
162
Node management LIF
Monitor server
UDP
162
Node management LIF
Monitor server
SnapMirror
TCP
11104
Intercluster LIF
ONTAP intercluster LIFs
TCP
11105
Intercluster LIF
Syslog
UDP
514
Node management LIF
Syslog server
Syslog forward messages
Rules for the HA mediator external security group
The predefined external security group for the Cloud Volumes ONTAP HA mediator includes the following inbound and outbound rules.
Inbound rules
The source for inbound rules is 0.0.0.0/0.
SSH
22
SSH connections to the HA mediator
TCP
3000
RESTful API access from Cloud Manager
Outbound rules
The predefined security group for the HA mediator opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the HA mediator includes the following outbound rules.
All TCP
All
All UDP
All
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the HA mediator.
API
HTTPS
443
AWS API services
Assist with storage failover
API
UDP
53
AWS API services
Note Rather than open these two ports, you can use a private endpoint instead.
Rules for the HA mediator internal security group
The predefined internal security group for the Cloud Volumes ONTAP HA mediator includes the following rules. Cloud Manager always creates this security group. You do not have the option to use your own.
Inbound rules
The predefined security group includes the following inbound rules.
All traffic
All
Communication between the HA mediator and HA nodes
Outbound rules
The predefined security group includes the following outbound rules.
All traffic
All
