Security group rules for AWS
Cloud Manager creates AWS security groups that include the inbound and outbound rules that Cloud Manager and Cloud Volumes ONTAP need to operate successfully. You might want to refer to the ports for testing purposes or if you prefer your to use own security groups.
Rules for Cloud Manager
The security group for Cloud Manager requires both inbound and outbound rules.
Inbound rules for Cloud Manager
The source for inbound rules in the predefined security group is 0.0.0.0/0.
| Protocol | Port | Purpose |
SSH |
22 |
Provides SSH access to the Cloud Manager host |
HTTP |
80 |
Provides HTTP access from client web browsers to the Cloud Manager web console |
HTTPS |
443 |
Provides HTTPS access from client web browsers to the Cloud Manager web console |
Outbound rules for Cloud Manager
The predefined security group for Cloud Manager opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Manager includes the following outbound rules.
All TCP |
All |
All outbound traffic |
All UDP |
All |
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Manager.
The source IP address is the Cloud Manager host. |
| Service | Protocol | Port | Destination | Purpose |
Active Directory |
TCP |
88 |
Active Directory forest |
Kerberos V authentication |
TCP |
139 |
NetBIOS service session |
TCP |
389 |
LDAP |
TCP |
445 |
Microsoft SMB/CIFS over TCP with NetBIOS framing |
TCP |
464 |
Kerberos V change & set password (SET_CHANGE) |
TCP |
749 |
Active Directory Kerberos V change & set password (RPCSEC_GSS) |
UDP |
137 |
NetBIOS name service |
UDP |
138 |
NetBIOS datagram service |
UDP |
464 |
Kerberos key administration |
API calls and AutoSupport |
HTTPS |
443 |
Outbound internet and ONTAP cluster management LIF |
API calls to AWS and ONTAP, and sending AutoSupport messages to NetApp |
API calls |
TCP |
3000 |
API calls to ONTAP |
DNS |
UDP |
53 |
DNS |
Used for DNS resolve by Cloud Manager |
Rules for Cloud Volumes ONTAP
The security group for Cloud Volumes ONTAP requires both inbound and outbound rules.
Inbound rules for Cloud Volumes ONTAP
All ICMP |
All |
Pinging the instance |
HTTP |
80 |
HTTP access to the System Manager web console using the IP address of the cluster management LIF |
HTTPS |
443 |
HTTPS access to the System Manager web console using the IP address of the cluster management LIF |
SSH |
22 |
SSH access to the IP address of the cluster management LIF or a node management LIF |
TCP |
111 |
Remote procedure call for NFS |
TCP |
139 |
NetBIOS service session for CIFS |
TCP |
161-162 |
Simple network management protocol |
TCP |
445 |
TCP |
635 |
NFS mount |
TCP |
749 |
Kerberos |
TCP |
2049 |
NFS server daemon |
TCP |
3260 |
iSCSI access through the iSCSI data LIF |
TCP |
4045 |
NFS lock daemon |
TCP |
4046 |
Network status monitor for NFS |
TCP |
10000 |
Backup using NDMP |
TCP |
11104 |
Management of intercluster communication sessions for SnapMirror |
TCP |
11105 |
SnapMirror data transfer using intercluster LIFs |
UDP |
111 |
UDP |
161-162 |
UDP |
635 |
NFS mount |
UDP |
2049 |
NFS server daemon |
UDP |
4045 |
NFS lock daemon |
UDP |
4046 |
UDP |
4049 |
NFS rquotad protocol |
Outbound rules for Cloud Volumes ONTAP
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
All ICMP |
All |
All TCP |
All |
All UDP |
All |
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
The source is the interface (IP address) on the Cloud Volumes ONTAP system. |
| Service | Protocol | Port | Source | Destination | Purpose |
Active Directory |
TCP |
88 |
Node management LIF |
UDP |
137 |
UDP |
138 |
TCP |
139 |
TCP |
389 |
LDAP |
TCP |
445 |
TCP |
464 |
UDP |
464 |
TCP |
749 |
Kerberos V change & set Password (RPCSEC_GSS) |
TCP |
88 |
Data LIF (NFS, CIFS) |
UDP |
137 |
UDP |
138 |
TCP |
139 |
TCP |
389 |
LDAP |
TCP |
445 |
TCP |
464 |
UDP |
464 |
TCP |
749 |
Cluster |
All traffic |
All traffic |
All LIFs on one node |
All LIFs on the other node |
Intercluster communications (Cloud Volumes ONTAP HA only) |
TCP |
3000 |
HA mediator |
ZAPI calls (Cloud Volumes ONTAP HA only) |
ICMP |
1 |
HA mediator |
Keep alive (Cloud Volumes ONTAP HA only) |
DHCP |
UDP |
68 |
DHCP |
DHCP client for first-time setup |
DHCPS |
UDP |
67 |
DHCP |
DHCP server |
DNS |
UDP |
53 |
Node management LIF and data LIF (NFS, CIFS) |
DNS |
DNS |
NDMP |
TCP |
18600–18699 |
Destination servers |
NDMP copy |
SMTP |
TCP |
25 |
Mail server |
SMTP alerts, can be used for AutoSupport |
SNMP |
TCP |
161 |
Monitor server |
Monitoring by SNMP traps |
UDP |
161 |
Monitor server |
TCP |
162 |
Monitor server |
UDP |
162 |
Monitor server |
SnapMirror |
TCP |
11104 |
Intercluster LIF |
ONTAP intercluster LIFs |
TCP |
11105 |
Intercluster LIF |
SnapMirror data transfer |
Syslog |
UDP |
514 |
Syslog server |
Syslog forward messages |
Rules for the HA mediator external security group
The predefined external security group for the Cloud Volumes ONTAP HA mediator includes the following inbound and outbound rules.
Inbound rules
The source for inbound rules is 0.0.0.0/0.
SSH |
22 |
SSH connections to the HA mediator |
TCP |
3000 |
RESTful API access from Cloud Manager |
Outbound rules
The predefined security group for the HA mediator opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the HA mediator includes the following outbound rules.
All TCP |
All |
All UDP |
All |
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the HA mediator.
HTTP |
80 |
Cloud Manager IP address |
Download upgrades for the mediator |
HTTPS |
443 |
AWS API services |
Assist with storage failover |
UDP |
53 |
AWS API services |
Rather than open ports 443 and 53, you can create an interface VPC endpoint from the target subnet to the AWS EC2 service. |
Rules for the HA mediator internal security group
The predefined internal security group for the Cloud Volumes ONTAP HA mediator includes the following rules. Cloud Manager always creates this security group. You do not have the option to use your own.
Inbound rules
The predefined security group includes the following inbound rules.
All traffic |
All |
Communication between the HA mediator and HA nodes |
Outbound rules
The predefined security group includes the following outbound rules.
All traffic |
All |
