Go to the docs for the latest release.
Learn about Cloud Volumes Service for AWS
NetApp Cloud Volumes Service for AWS is a cloud native file service that provides NAS volumes over NFS and SMB with all-flash performance. This service enables any workload, including legacy applications, to run in the AWS cloud.
Benefits of using Cloud Volumes Service for AWS
Cloud Volumes Service for AWS provides the following benefits:
Fully managed service, therefore no need to configure or manage storage devices
Support for NFSv3 and NFSv4.1, and SMB 3.0 and 3.1.1 NAS protocols
Secure access to Linux and Windows Elastic Container Service (ECS) instances, with support including the following:
Amazon Linux 2, Red Hat Enterprise Linux 7.5, SLES 12 SP3, and Ubuntu 16.04 LTS
Windows Server 2008 R2, Windows Server 2012 R2, and Windows Server 2016
Choice of bundled and pay-as-you-go pricing
Cost
Volumes created by the Cloud Volumes Service for AWS are charged based on your subscription to the service, not through Cloud Manager.
There are no charges to discover a Cloud Volumes Service for AWS region or volume from Cloud Manager.
Before you get started
Cloud Manager can discover existing Cloud Volumes Service for AWS subscriptions and volumes. See the NetApp Cloud Volumes Service for AWS Account Setup Guide if you haven’t set up your subscription yet. You must follow this setup process for each region before you can add the AWS subscriptions and volumes in Cloud Manager.
You need to obtain the Cloud Volumes API key and secret key so you can provide them to Cloud Manager. For instructions, refer to Cloud Volumes Service for AWS documentation.
Quick start
Get started quickly by following these steps, or go to the next section for full details.
Verify support for your configuration
You have set up AWS for Cloud Volumes Service and you must have subscribed to one of the NetApp Cloud Volumes Service offerings on the AWS Marketplace.
Add your Cloud Volumes Service for AWS subscription
You must create a working environment for the volumes based on your Cloud Volumes Service for AWS subscription.
Create a cloud volumes
Cloud volumes that already exist for this subscription appear in the new working environment. Otherwise you create new volumes from Cloud Manager.
Mount a cloud volume
Mount new cloud volumes to your AWS instance so that users can begin to use the storage.
Getting help
Use the Cloud Manager chat for general service questions.
For technical support issues associated with your cloud volumes, use your 20 digit “930” serial number located in the "Support" tab of the Cloud Volumes Service user interface. Use this support ID when opening a web ticket or calling for support. Be sure to activate your Cloud Volumes Service serial number for support from the Cloud Volumes Service user interface. Those steps are explained here.
Limitations
Cloud Manager doesn’t support data replication between working environments when using Cloud Volumes Service volumes.
Removing your Cloud Volumes Service for AWS subscription from Cloud Manager isn’t supported. You can do this only through the Cloud Volumes Service for AWS interface.
