Learn about Global File Cache
NetApp Global File Cache enables you to consolidate silos of distributed file servers into one cohesive global storage footprint in the public cloud. This creates a globally accessible file system in the cloud that all remote locations can use as if they were local.
Overview
Implementing Global File Cache results in a single, centralized storage footprint, versus a distributed storage architecture that requires local data management, backup, security management, storage, and infrastructure footprint in each location.
Features
Global File Cache enables the following features:
Consolidate and centralize your data into the public cloud and leverage the scalability and performance from enterprise-grade storage solutions
Create a single set of data for users globally and leverage intelligent file caching to improve global data access, collaboration, and performance
Rely on a self-sustaining, self-managing cache, and eliminate full data copies and backups. Utilize local file caching for active data and cut storage costs
Transparent access from branch locations through a global namespace with real time central file locking
See more about Global File Cache features and use cases here.
Global File Cache components
Global File Cache consists of the following components:
Global File Cache Management Server
Global File Cache Core
Global File Cache Edge (deployed in your remote locations)
The Global File Cache Core instance mounts to your corporate file shares hosted on your backend storage platform of choice (such as Cloud Volumes ONTAP, Cloud Volumes Service, and Azure NetApp Files) and creates the Global File Cache Fabric that provides the ability to centralize and consolidate unstructured data into a single set of data, whether it resides on one or multiple storage platforms in the public cloud.
Supported storage platforms
The supported storage platforms for Global File Cache differ depending on the deployment option you select.
Automated deployment options
Global File Cache is supported with the following types of working environments when deployed using Cloud Manager:
Cloud Volumes ONTAP in Azure
Cloud Volumes ONTAP in AWS
This configuration lets you deploy and manage the entire Global File Cache server-side deployment, including Global File Cache Management Server and Global File Cache Core, from within Cloud Manager.
Manual deployment options
Global File Cache configurations are also supported with Cloud Volumes ONTAP, Cloud Volumes Service, or Azure NetApp Files installed on Microsoft Azure, Google Cloud Platform, or Amazon Web Services public cloud storage infrastructure. On-premises solutions are also available on NetApp AFF and FAS platforms. In these installations the Global File Cache server-side components must be configured and deployed manually, not using Cloud Manager.
See the NetApp Global File Cache User Guide for details.
How Global File Cache works
Global File Cache creates a software fabric that caches active data sets in remote offices globally. As a result, business users are guaranteed transparent data access and optimal performance on a global scale.
The topology referenced in this example is a hub and spoke model, whereby the network of remote offices/locations is accessing one common set of data in the cloud. The key points of this example are:
Centralized data store:
Enterprise public cloud storage platform, such as Cloud Volumes ONTAP
Global File Cache Fabric:
Extension of the central data store to the remote locations
Global File Cache Core instance, mounting to corporate file shares (SMB).
Global File Cache Edge instances running in each remote location.
Presents a virtual file share in each remote location that provides access to central data.
Hosts the Intelligent File Cache on a custom-sized NTFS volume (
D:\).
Network configuration:
Multiprotocol Label Switching (MPLS), ExpressRoute, or VPN connectivity
Integration with customer’s Active Directory domain services.
DFS namespace for the use of a global namespace (recommended).
Cost
The cost to use Global File Cache depends on the type of installation you have chosen.
All installations require that you deploy one or more volumes in the cloud (Cloud Volumes ONTAP, Cloud Volumes Service, or Azure NetApp Files). This results in charges from the selected cloud provider.
All installations also require that you deploy two or more virtual machines (VMs) in the cloud. This results in charges from the selected cloud provider.
Global File Cache Management Server:
In Azure, this runs on a D2s_V3 or equivalent (2 vCPU/8GB RAM) VM with 127GB premium SSD
In AWS, this runs on a m4.large or equivalent (2 vCPU/8GB RAM) instance with 127GB general purpose SSD
Global File Cache Core:
In Azure, this runs on a D4s_V3 or equivalent (4 vCPU/16GB RAM) VM with 127GB premium SSD
In AWS, this runs on a m4.xlarge or equivalent (4 vCPU/16GB RAM) instance with 127GB general purpose SSD
When installed with Cloud Volumes ONTAP in Azure or AWS (the supported configurations deployed completely through Cloud Manager), there is a charge of $3,000 per site (for each Global File Cache Edge instance), per year.
When installed using the manual deployment options the pricing is different. To see a high-level estimate of costs, see Calculate Your Savings Potential or consult your Global File Cache Solutions Engineer to discuss the best options for your enterprise deployment.
Licensing
Global File Cache includes a software-based License Management Server (LMS), which allows you to consolidate your license management and deploy licenses to all Core and Edge instances using an automated mechanism.
When you deploy your first Core instance in the datacenter or cloud, you can choose to designate that instance as the LMS for your organization. This LMS instance is configured once, connects to the subscription service (over HTTPS) and validates your subscription using the customer ID provided by our support/operations department upon enablement of the subscription. After you have made this designation, you associate your Edge instances with the LMS by providing your customer ID and the IP address of the LMS instance.
When you purchase additional Edge licenses or renew your subscription, our support/operations department updates the license details, for example, the number of sites or subscription end date. After the LMS queries the subscription service, the license details are automatically updated on the LMS instance and will apply to your GFC Core and Edge instances.
See the NetApp Global File Cache User Guide for additional details about licensing.
Limitations
The version of Global File Cache supported within Cloud Manager requires that the backend storage platform used as your central storage must be a working environment where you have deployed a Cloud Volumes ONTAP single node or HA pair in Azure or AWS.
Other storage platforms and other cloud providers are not supported at this time using Cloud Manager, but can be deployed using legacy deployment procedures.
These other configurations, for example, Global File Cache using Cloud Volumes ONTAP, Cloud Volumes Service, and Azure NetApp Files on Microsoft Azure, Google Cloud, and AWS continue to be supported using the legacy procedures. See Global File Cache overview and onboarding for details.
