Disks and aggregates
Understanding how Cloud Volumes ONTAP uses cloud storage can help you understand your storage costs.
All disks and aggregates must be created and deleted directly from Cloud Manager. You should not perform these actions from another management tool. Doing so can impact system stability, hamper the ability to add disks in the future, and potentially generate redundant cloud provider fees. |
Overview
Cloud Volumes ONTAP uses cloud provider storage as disks and groups them into one or more aggregates. Aggregates provide storage to one or more volumes.
Several types of cloud disks are supported. You choose the disk type when you create a volume and the default disk size when you deploy Cloud Volumes ONTAP.
The total amount of storage purchased from a cloud provider is the raw capacity. The usable capacity is less because approximately 12 to 14 percent is overhead that is reserved for Cloud Volumes ONTAP use. For example, if Cloud Manager creates a 500 GB aggregate, the usable capacity is 442.94 GB. |
AWS storage
In AWS, Cloud Volumes ONTAP uses EBS storage for user data and local NVMe storage as Flash Cache on some EC2 instance types.
- EBS storage
In AWS, an aggregate can contain up to 6 disks that are all the same size. The maximum disk size is 16 TB.
The underlying EBS disk type can be either General Purpose SSD, Provisioned IOPS SSD, Throughput Optimized HDD, or Cold HDD. You can pair an EBS disk with Amazon S3 to tier inactive data to low-cost object storage.
At a high level, the differences between EBS disk types are as follows:
General Purpose SSD disks balance cost and performance for a broad range of workloads. Performance is defined in terms of IOPS.
Provisioned IOPS SSD disks are for critical applications that require the highest performance at a higher cost.
Throughput Optimized HDD disks are for frequently accessed workloads that require fast and consistent throughput at a lower price.
Cold HDD disks are meant for backups, or infrequently accessed data, because the performance is very low. Like Throughput Optimized HDD disks, performance is defined in terms of throughput.
Cold HDD disks are not supported with HA configurations and with data tiering.
- Local NVMe storage
Some EC2 instance types include local NVMe storage, which Cloud Volumes ONTAP uses as Flash Cache.
Related links
Azure storage
In Azure, an aggregate can contain up to 12 disks that are all the same size. The disk type and maximum disk size depends on whether you use a single node system or an HA pair:
- Single node systems
Single node systems can use three types of Azure Managed Disks:
Premium SSD Managed Disks provide high performance for I/O-intensive workloads at a higher cost.
Standard SSD Managed Disks provide consistent performance for workloads that require low IOPS.
Standard HDD Managed Disks are a good choice if you don't need high IOPS and want to reduce your costs.
Each managed disk type has a maximum disk size of 32 TB.
You can pair a managed disk with Azure Blob storage to tier inactive data to low-cost object storage.
- HA pairs
HA pairs use Premium page blobs, which have a maximum disk size of 8 TB.
Related links
GCP storage
In GCP, an aggregate can contain up to 6 disks that are all the same size. The maximum disk size is 16 TB.
The disk type can be either Zonal SSD persistent disks or Zonal standard persistent disks. You can pair persistent disks with a Google Storage bucket to tier inactive data to low-cost object storage.
Related links
RAID type
The RAID type for each Cloud Volumes ONTAP aggregate is RAID0 (striping). No other RAID types are supported. Cloud Volumes ONTAP relies on the cloud provider for disk availability and durability.
