Security group rules for AWS
Cloud Manager creates AWS security groups that include the inbound and outbound rules that the Connector and Cloud Volumes ONTAP need to operate successfully. You might want to refer to the ports for testing purposes or if you prefer your to use own security groups.
Rules for Cloud Volumes ONTAP
The security group for Cloud Volumes ONTAP requires both inbound and outbound rules.
Inbound rules
The source for inbound rules in the predefined security group is 0.0.0.0/0.
Protocol | Port | Purpose |
All ICMP |
All |
Pinging the instance |
HTTP |
80 |
HTTP access to the System Manager web console using the IP address of the cluster management LIF |
HTTPS |
443 |
HTTPS access to the System Manager web console using the IP address of the cluster management LIF |
SSH |
22 |
SSH access to the IP address of the cluster management LIF or a node management LIF |
TCP |
111 |
Remote procedure call for NFS |
TCP |
139 |
NetBIOS service session for CIFS |
TCP |
161-162 |
Simple network management protocol |
TCP |
445 |
Microsoft SMB/CIFS over TCP with NetBIOS framing |
TCP |
635 |
NFS mount |
TCP |
749 |
Kerberos |
TCP |
2049 |
NFS server daemon |
TCP |
3260 |
iSCSI access through the iSCSI data LIF |
TCP |
4045 |
NFS lock daemon |
TCP |
4046 |
Network status monitor for NFS |
TCP |
10000 |
Backup using NDMP |
TCP |
11104 |
Management of intercluster communication sessions for SnapMirror |
TCP |
11105 |
SnapMirror data transfer using intercluster LIFs |
UDP |
111 |
UDP |
161-162 |
UDP |
635 |
NFS mount |
UDP |
2049 |
NFS server daemon |
UDP |
4045 |
NFS lock daemon |
UDP |
4046 |
UDP |
4049 |
NFS rquotad protocol |
Outbound rules
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
All ICMP |
All |
All outbound traffic |
All TCP |
All |
All UDP |
All |
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
The source is the interface (IP address) on the Cloud Volumes ONTAP system. |
Service | Protocol | Port | Source | Destination | Purpose |
Active Directory |
TCP |
88 |
Node management LIF |
Active Directory forest |
Kerberos V authentication |
UDP |
137 |
NetBIOS name service |
UDP |
138 |
NetBIOS datagram service |
TCP |
139 |
NetBIOS service session |
TCP & UDP |
389 |
LDAP |
TCP |
445 |
TCP |
464 |
Kerberos V change & set password (SET_CHANGE) |
UDP |
464 |
Kerberos key administration |
TCP |
749 |
Kerberos V change & set Password (RPCSEC_GSS) |
TCP |
88 |
Data LIF (NFS, CIFS, iSCSI) |
UDP |
137 |
Data LIF (NFS, CIFS) |
UDP |
138 |
TCP |
139 |
TCP & UDP |
389 |
LDAP |
TCP |
445 |
TCP |
464 |
UDP |
464 |
TCP |
749 |
Kerberos V change & set password (RPCSEC_GSS) |
Backup to S3 |
TCP |
5010 |
Intercluster LIF |
Backup endpoint or restore endpoint |
Back up and restore operations for the Backup to S3 feature |
Cluster |
All traffic |
All traffic |
All LIFs on one node |
All LIFs on the other node |
Intercluster communications (Cloud Volumes ONTAP HA only) |
TCP |
3000 |
HA mediator |
ZAPI calls (Cloud Volumes ONTAP HA only) |
ICMP |
1 |
HA mediator |
Keep alive (Cloud Volumes ONTAP HA only) |
DHCP |
UDP |
68 |
DHCP |
DHCP client for first-time setup |
DHCPS |
UDP |
67 |
DHCP |
DHCP server |
DNS |
UDP |
53 |
Node management LIF and data LIF (NFS, CIFS) |
DNS |
DNS |
NDMP |
TCP |
18600–18699 |
Destination servers |
NDMP copy |
SMTP |
TCP |
25 |
Mail server |
SMTP alerts, can be used for AutoSupport |
SNMP |
TCP |
161 |
Monitor server |
Monitoring by SNMP traps |
UDP |
161 |
Monitor server |
TCP |
162 |
Monitor server |
UDP |
162 |
Monitor server |
SnapMirror |
TCP |
11104 |
Intercluster LIF |
ONTAP intercluster LIFs |
TCP |
11105 |
Intercluster LIF |
SnapMirror data transfer |
Syslog |
UDP |
514 |
Syslog server |
Syslog forward messages |
Rules for the HA mediator external security group
The predefined external security group for the Cloud Volumes ONTAP HA mediator includes the following inbound and outbound rules.
Inbound rules
The source for inbound rules is 0.0.0.0/0.
SSH |
22 |
SSH connections to the HA mediator |
TCP |
3000 |
RESTful API access from the Connector |
Outbound rules
The predefined security group for the HA mediator opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the HA mediator includes the following outbound rules.
All TCP |
All |
All UDP |
All |
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the HA mediator.
Protocol | Port | Destination | Purpose |
HTTP |
80 |
Connector IP address |
Download upgrades for the mediator |
HTTPS |
443 |
AWS API services |
Assist with storage failover |
UDP |
53 |
AWS API services |
Rather than open ports 443 and 53, you can create an interface VPC endpoint from the target subnet to the AWS EC2 service. |
Rules for the HA mediator internal security group
The predefined internal security group for the Cloud Volumes ONTAP HA mediator includes the following rules. Cloud Manager always creates this security group. You do not have the option to use your own.
Inbound rules
The predefined security group includes the following inbound rules.
All traffic |
All |
Communication between the HA mediator and HA nodes |
Outbound rules
The predefined security group includes the following outbound rules.
All traffic |
All |
Rules for the Connector
The security group for the Connector requires both inbound and outbound rules.
Inbound rules
SSH |
22 |
Provides SSH access to the Connector host |
HTTP |
80 |
Provides HTTP access from client web browsers to the local user interface and connections from Cloud Compliance |
HTTPS |
443 |
Provides HTTPS access from client web browsers to the local user interface |
TCP |
3128 |
Provides the Cloud Compliance instance with internet access, if your AWS network doesn’t use a NAT or proxy |
Outbound rules
The predefined security group for the Connector opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the Connector includes the following outbound rules.
All TCP |
All |
All UDP |
All |
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the Connector.
The source IP address is the Connector host. |
Service | Protocol | Port | Destination | Purpose |
Active Directory |
TCP |
88 |
TCP |
139 |
TCP |
389 |
LDAP |
TCP |
445 |
TCP |
464 |
TCP |
749 |
Active Directory Kerberos V change & set password (RPCSEC_GSS) |
UDP |
137 |
UDP |
138 |
UDP |
464 |
API calls and AutoSupport |
HTTPS |
443 |
Outbound internet and ONTAP cluster management LIF |
API calls to AWS and ONTAP, and sending AutoSupport messages to NetApp |
API calls |
TCP |
3000 |
API calls to ONTAP |
TCP |
8088 |
Backup to S3 |
API calls to Backup to S3 |
DNS |
UDP |
53 |
DNS |
Used for DNS resolve by Cloud Manager |
Cloud Compliance |
HTTP |
80 |
Cloud Compliance instance |
Cloud Compliance for Cloud Volumes ONTAP |
