OnCommand Insight
Uninstalling an Ethernet Monitoring Unit
You can uninstall an Ethernet Monitoring Unit when you no longer need it.
About this task
Note
Ethernet Monitoring Unit (EMU) is not supported in OnCommand Insight version 7.3.12 and later.
Steps
  1. Log in to the Ethernet Monitoring Unit server using an account with sudo privileges.
  2. Ensure that any OnCommand Insight windows are closed.
  3. You can view syntax, command arguments, and parameter usage for uninstall.sh by entering the following command: sudo /usr/bin/oci-uninstall.sh --help
  4. Type the following command: sudo /usr/bin/oci-uninstall.sh
    The uninstall script runs. Follow any prompts.
  5. After uninstall is complete, restart the server.
