OnCommand Insight
Uninstalling the anomaly detection engine
You can uninstall the anomaly detection engine when you no longer need it.
Steps
  1. Log in to the server where you installed the anomaly detection engine software, using an account with sudo privileges.
  2. Ensure that any OnCommand Insight windows are closed.
  3. You can view syntax, command arguments, and parameter usage for uninstall.sh by entering the following command: sudo /usr/bin/oci-prelert-uninstall.sh --help
  4. Type the following command: sudo /usr/bin/oci-prelert-uninstall.sh
    The uninstall script runs. Follow any prompts.
