Upgrading the anomaly detection engine
PDF of this doc site
Configuration and administration
Data Warehouse administration
Creating your file...
Your file is ready
Starting with OnCommand Insight version 7.3.9 you can perform an in-line upgrade of the anomaly detection software. The in-line upgrade preserves your anomaly detection data and anomaly scores.
Before you begin
The system must be running OnCommand Insight 7.3.7 or later.
It is recommended to upgrade the OnCommand Insight Server prior to upgrading the Anomaly Detection Engine.
About this task
Use the following steps to upgrade:
Steps
Navigate to the directory where the installer is located:
cd oci-prelert-<version>-linux-x86_64
Install the anomaly detection upgrade software:
sudo ./oci-prelert-install.sh
The anomaly detection software is successfully registered with the OnCommand Insight server.
