Add Annotation dialog box
The Add Annotation dialog box enables you to create custom annotations that you can associate with clusters, volumes, and storage virtual machines (SVMs) through annotation rules.
You must have the OnCommand Administrator or Storage Administrator role.
Annotation Name
Specifies the name of the annotation. You must enter a unique name for the annotation.
Specifies a meaningful description of the annotation.
Annotation Values
Add
Adds a new value to the selected annotation.
Delete
Deletes the selected value for an annotation.
Command buttons
Save and Close
Saves the new annotation and closes the Add Annotation dialog box dialog box.
Cancel
Closes the Add Annotation dialog box without saving your changes.
