Aggregate Capacity and Utilization report
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
The Aggregate Capacity and Utilization report enables you to view information about the capacity and utilization of aggregates in a cluster. This information enables you to understand possible capacity risks and also to view the configured, used, and unused capacity of aggregates.
Aggregate Capacity and Utilization report tabular view
Cluster
Displays the cluster name.
HA Pair
Displays the HA pair value obtained by forming two nodes.
Aggregate
Displays the aggregate name.
Total Data Capacity (GB)
Displays the total data capacity (used plus available).
Used Data Capacity (GB)
Displays the used data capacity.
Used Data %
Displays the used data capacity as a percentage.
Available Data Capacity (GB)
Displays the available data capacity.
Available Data %
Displays the available data capacity as a percentage.
Daily Growth Rate %
Displays the growth rate that occurs every 24 hours in the volume.
Days To Full
Displays the estimated number of days remaining before the aggregate reaches full capacity.
Space Full Threshold
Displays the percentage at which an aggregate is full.
Space Nearly Full Threshold
Displays the percentage at which an aggregate is nearly full.
Growth Rate Threshold
Specifies the aggregate's growth rate is considered to be normal before the system generates an Aggregate Growth Rate Abnormal event.
Growth Rate Sensitivity Threshold
Specifies the factor that is applied to the standard deviation of a volume's growth rate. If the growth rate exceeds the factored standard deviation, a Volume Growth Rate Abnormal event is generated.
Days Until Full Threshold
Specifies the number of days remaining before the aggregate reaches full capacity.
Snapshot Reserve Total Capacity (GB)
Displays the total snapshot reserve capacity of the aggregate.
Snapshot Reserve Used Capacity (GB)
Displays the amount of space used by snapshot copies from snapshot reserve.
Snapshot Reserve Used %
Displays the amount of space used by Snapshot copies from snapshot reserve as a percentage.
Snapshot Reserve Available Capacity (GB)
Displays the amount of space available for Snapshot copies.
Snapshot Reserve Available %
Displays the amount of space available for Snapshot copies as a percentage.
Snapshot Copies Reserve Full Threshold
Specifies the percentage at which an aggregate has consumed all its space reserved for Snapshot copies.
Overcommitted Capacity %
Displays the aggregate overcommitment as a percentage.
Overcommitted Threshold %
Displays the percentage at which an aggregate is overcommitted.
Nearly Overcommitted Threshold %
Displays the percentage at which an aggregate is nearly overcommitted.
Type
Displays the aggregate type:
HDD
Hybrid
Combines HDDs and SSDs, but Flash Pool has not been enabled.
Hybrid (Flash Pool)
Combines HDDs and SSDs, and Flash Pool has been enabled.
SSD
SSD (FabricPool)
Combines SSDs and a cloud tier
VMDisk (SDS)
Virtual disks within a virtual machine
VMDisk (FabricPool)
Combines virtual disks and a cloud tier
LUN (FlexArray) For standard disks and SSD disks, this column is blank when the monitored storage system is running an ONTAP version earlier than 8.3.
RAID Type
Displays the RAID configuration type.
Aggregate State
Displays the current state of the aggregate.
SnapLock Type
Indicates whether the aggregate is a SnapLock or non-SnapLock aggregate.
Cloud Tier Space Used (GB)
Displays the amount of data capacity that is currently being used in the cloud tier.
Cloud Tier
Displays the name of the cloud tier when it was created by ONTAP.
