Health/Aggregates Capacity and Utilization page
The Health/Aggregates Capacity and Utilization page enables you to view information about the capacity and utilization of aggregates in all clusters. This information enables you to understand possible capacity risks and also to view the configured, used, and unused capacity of aggregates.
Use the Export button to export the details of all the monitored aggregates to a comma-separated values (.csv) file.
Cluster
The cluster name.
HA Pair
The HA pair value obtained by forming two nodes.
Aggregate
The aggregate name.
Total Data Capacity
The total data capacity (used plus available).
Used Data Capacity
The used data capacity.
Used Data %
The used data capacity as a percentage.
Available Data Capacity
The available data capacity.
Available Data %
The available data capacity as a percentage.
Daily Growth Rate %
The growth rate that occurs every 24 hours in the aggregate.
Days To Full
The estimated number of days remaining before the aggregate reaches full capacity.
Space Full Threshold %
The percentage at which an aggregate is considered full.
Space Nearly Full Threshold %
The percentage at which an aggregate is considered nearly full.
Growth Rate Threshold
The aggregate's growth rate that is considered to be normal before the system generates an Aggregate Growth Rate Abnormal event.
Growth Rate Sensitivity Threshold
The factor that is applied to the standard deviation of a aggregate's growth rate. If the growth rate exceeds the factored standard deviation, an Aggregate Growth Rate Abnormal event is generated.
Days Until Full Threshold
The number of days remaining before the aggregate reaches full capacity.
Snapshot Reserve Total Capacity
The total snapshot reserve capacity of the aggregate.
Snapshot Reserve Used Capacity
The amount of space used by snapshot copies from the snapshot reserve.
Snapshot Reserve Used %
The amount of space used by Snapshot copies from the snapshot reserve as a percentage.
Snapshot Reserve Available Capacity
The amount of space available for Snapshot copies.
Snapshot Reserve Available %
The amount of space available for Snapshot copies as a percentage.
Snapshot Copies Reserve Full Threshold %
The percentage at which an aggregate has consumed all its space reserved for Snapshot copies.
Overcommitted Capacity %
The aggregate overcommitment as a percentage.
Overcommitted Threshold %
The percentage at which an aggregate is considered overcommitted.
Nearly Overcommitted Threshold %
The percentage at which an aggregate is considered nearly overcommitted.
Aggregate Type
The aggregate type:
HDD
Hybrid
Combines HDDs and SSDs, but Flash Pool has not been enabled.
Hybrid (Flash Pool)
Combines HDDs and SSDs, and Flash Pool has been enabled.
SSD
SSD (FabricPool)
Combines SSDs and a cloud tier
VMDisk (SDS)
Virtual disks within a virtual machine
VMDisk (FabricPool)
Combines virtual disks and a cloud tier
LUN (FlexArray) For standard disks and SSD disks, this column is blank when the monitored storage system is running an ONTAP version earlier than 8.3.
RAID Type
The RAID configuration type.
Aggregate State
The current state of the aggregate.
SnapLock Type
Whether the aggregate is a SnapLock or non-SnapLock aggregate.
Cloud Tier Space Used
The amount of data capacity that is currently being used in the cloud tier.
Cloud Tier
The name of the cloud tier object store when it was created by ONTAP.
