Storage Summary report
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
The Storage Summary report enables you to view summarized information about storage capacity in the HA pairs. This information helps you to understand possible capacity risks and to take appropriate action to rebalance workload. Single-node cluster information is not visible in the report.
Storage Summary report chart view
The Storage Summary report is displayed in two formats:
Storage Summary report tabular view
The chart shows the capacity trend of used and unused data capacity of the aggregates over a period of time. Total data capacity is displayed on the vertical (y) axis and the cluster name on the horizontal (x) axis. Therefore, each bar in the chart represents one cluster. You can view the details for specific points on the graph by positioning your cursor over a particular point.
Cluster Name
Displays the cluster name.
HA Pair
Displays the HA pair value obtained by forming two nodes.
Model
Displays the name of the model.
OS Version
Displays the version of ONTAP used.
Total Raw Capacity
Displays the total physical capacity of all disks in the array.
Unconfigured Raw Capacity
Displays the unconfigured capacity of disks whose container type is other than aggregate, broken, spare, or shared. This capacity is always higher than the physical capacity of the disk in ONTAP. For example, consider a 2 TB disk. The physical capacity of the disk is 1.6 TB in ONTAP whereas the unconfigured raw capacity in Unified Manager is 1.8 TB.
Aggregate Total Capacity
Displays the total size of the available aggregates for the user. This includes the Snapshot copy reserve.
Aggregate Used Capacity
Displays the capacity already in use on aggregates. This includes the capacity consumed by volumes, LUNs, and other storage efficiency technology overheads.
Aggregate Unused Capacity
Displays capacity that might be available for storing additional data on the aggregate. This includes the Snapshot copy reserve.
Allocated LUN Capacity
Displays the capacity of LUNs that are mapped.
Unallocated LUN Capacity
Displays the capacity of all LUNs not mapped to the Host.
Volume Total Capacity
Displays the total capacity of the volumes (used plus unused).
Volume Used Capacity
Displays the used capacity of the volumes.
Volume Unused Capacity
Displays the unused capacity of the volumes.
Volume Protection Capacity
Displays the capacity of volumes that have SnapMirror and SnapVault enabled.
Cluster Licensed Cloud Tier Total
Displays the total capacity that has been licensed in the cloud tier. This field is displayed for storage providers that require a FabricPool license, for example, Amazon S3, IBM Cloud Object Storage, Microsoft Azure Cloud, or Alibaba Cloud Object Storage.
Cluster Licensed Cloud Tier Used
Displays the space used by data in the cloud tier for storage providers that require a FabricPool license.
Cluster StorageGRID Capacity Used
Displays the space used by data in the cloud tier for storage providers that do not require a FabricPool license, for example, StorageGRID.
