Disable Events dialog box
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
The Disable Events dialog box displays the list of event types for which you can disable events. You can disable events for an event type based on a particular severity or for a set of events.
You must have the OnCommand Administrator or Storage Administrator role.
Event Properties area
The Event Properties area specifies the following event properties:
Event Severity
Enables you to select events based on the severity type, which can be Critical, Error, Warning, or Information.
Event Name Contains
Enables you to filter events whose name contains the specified characters.
Matching events
Displays the list of events matching the event severity type and the text string you specify.
Disable events
Displays the list of events that you have selected for disabling.
The severity of the event is also displayed along with the event name.
Command buttons
The command buttons enable you to perform the following tasks for the selected events:
Save and close
Disables the event type and closes the dialog box.
Cancel
Discards the changes and closes the dialog box.
