Lag Thresholds for Unmanaged Relationships page
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
The Lag Thresholds for Unmanaged Relationships page enables you to configure global lag warning and error threshold values for unmanaged protection relationships so that you are notified and can take action when lag or threshold errors occur. Changes to these settings are applied during the next scheduled update.
You must have the OnCommand Administrator or Storage Administrator role.
Events are generated when a threshold is breached. You can take corrective actions for such events. Lag threshold settings for unmanaged relationships are enabled by default.
The lag threshold specifies a percentage that the lag time must not exceed. Using an example of one hour, if the lag threshold is defined as 150%, then you will receive an event when the lag time is more than 1.5 hours.
Lag Thresholds for Unmanaged Relationships area
The Lag area enables you set unmanaged relationship lag thresholds for the following conditions:
Warning
Specifies the percentage at which the lag duration equals or exceeds the lag warning threshold:
Default value: 150 percent
Events generated: SnapMirror Relationship Lag Warning or SnapVault Relationship Lag Warning
Event severity: Warning
Specifies the percentage at which the lag duration equals or exceeds the lag error threshold:
Default value: 250 percent
Events generated: SnapMirror Relationship Lag Error or SnapVault Relationship Lag Error
Event severity: Error
Command buttons
Restore to Factory Defaults
Enables you to restore the configuration settings to the factory default values.
Save
Saves the configuration settings for the selected option.
