MetroCluster Connectivity events
Connectivity events provide you with information about the connectivity between the components of a cluster and between clusters in a MetroCluster configuration so that you can monitor for potential problems. Events are grouped by impact area and include the event and trap name, impact level, source type, and severity.
Impact area: availability
| Event name(Trap name) | Impact level | Source type | Severity |
All Inter-Switch Links Down(ocumEvtMetroClusterAllISLBetweenSwitchesDown) |
Incident |
MetroCluster inter-switch connection |
Critical |
All Links Between MetroCluster Partners Down(ocumEvtMetroClusterAllLinksBetweenPartnersDown) |
Incident |
MetroCluster relationship |
Critical |
FC-SAS Bridge To Storage Stack Link Down(ocumEvtBridgeSasPortDown) |
Incident |
MetroCluster bridge stack connection |
Critical |
MetroCluster Configuration Switched Over((ocumEvtMetroClusterDRStatusImpacted) |
Risk |
Warning |
MetroCluster Configuration Partially Switched Over(ocumEvtMetroClusterDRStatusPartiallyImpacted) |
Risk |
Error |
MetroCluster Disaster Recovery Capability Impacted(ocumEvtMetroClusterDRStatusImpacted) |
Risk |
Critical |
MetroCluster Partners Not Reachable Over Peering Network(ocumEvtMetroClusterPartnersNotReachableOverPeeringNetwork) |
Incident |
Critical |
Node To FC Switch All FC-VI Interconnect Links Down(ocumEvtMccNodeSwitchFcviLinksDown) |
Incident |
MetroCluster node switch connection |
Critical |
Node To FC Switch One Or More FC-Initiator Links Down(ocumEvtMccNodeSwitchFcLinksOneOrMoreDown) |
Risk |
Warning |
Node To FC Switch All FC-Initiator Links Down(ocumEvtMccNodeSwitchFcLinksDown) |
Incident |
Critical |
Switch To FC-SAS Bridge FC Link Down (ocumEvtMccSwitchBridgeFcLinksDown) |
Incident |
MetroCluster switch bridge connection |
Critical |
Inter Node All FC VI InterConnect Links Down (ocumEvtMccInterNodeLinksDown) |
Incident |
Inter-node connection |
Critical |
Inter Node One Or More FC VI InterConnect Links Down (ocumEvtMccInterNodeLinksOneOrMoreDown) |
Risk |
Warning |
Node To Bridge Link Down (ocumEvtMccNodeBridgeLinksDown) |
Incident |
Node bridge connection |
Critical |
Node to Storage Stack All SAS Links Down ( ocumEvtMccNodeStackLinksDown) |
Incident |
Node stack connection |
Critical |
Node to Storage Stack One Or More SAS Links Down ( ocumEvtMccNodeStackLinksOneOrMoreDown) |
Risk |
Warning |
