Considerations for transitioning 7-Mode IP addresses
You must be aware of certain considerations when transitioning 7-Mode IP addresses to storage virtual machines (SVMs) in ONTAP.
You can transition existing 7-Mode IP addresses or specify new IP addresses to be configured on the SVM by using the 7-Mode Transition Tool.
Existing 7-Mode IP addresses are created on the SVM in the administrative
downstate in the apply configuration (precutover) phase. -
New IP addresses are created on the SVM in the administrative
upstate in the apply configuration (precutover) phase.
IPv6 addresses cannot be transitioned and must be manually configured after the transition.
iSCSI and FC LIFs are not transitioned and must be manually configured after the transition.
