NFS transition: supported and unsupported configurations, and required manual steps
Some NFS configurations are not transitioned to ONTAP because they are not supported in ONTAP, there are functionality differences from 7-Mode, or they must be manually transitioned. You should verify all of the precheck errors and warning messages to evaluate the impact of such configurations on transition.
Supported configurations for transition
At a high level, the following NFS configurations are transitioned by the 7-Mode Transition Tool:
NFS options:
nfs.udp.xfersize -
nfs.v4.id.domain -
nfs.v4.acl.max.aces -
nfs.tcp.xfersize -
nfs.rpcsec.ctx.high -
nfs.rpcsec.ctx.idle -
nfs.response.trigger -
wafl.default_nt_user -
nfs.mount_rootonly -
nfs.tcp.enable -
nfs.udp.enable -
nfs.response.trace -
nfs.v4.read_delegation -
nfs.v4.write_delegation -
nfs.v4.acl.enable -
nfs.vstorage.enable -
nfs.v3.enable -
nfs.v4.enable
NFS export rule:
If the export rule is configured with the
-actualoption, the exported path (alias path) is ignored and the export rule is configured with the actual path. -
Export rules with Kerberos security krb5p
Kerberos configuration
See the precheck results for details about these NFS configurations.
Unsupported configurations in ONTAP
The following NFS configurations are not supported in ONTAP:
Subvolume NFS exports other than qtree-level NFS exports
WebNFS
PC-NFS
NFSv2
Fencing of NFS clients from one or more file system paths
Some NFS options
See the precheck warning messages for a complete list of unsupported options.
Configurations that must be manually transitioned
There are some NFS configurations that are supported in ONTAP, but are not transitioned by the 7-Mode Transition Tool.
The following NFS configurations generate a warning message in the precheck operation, and you must manually apply the configurations on the SVM:
NFS audit configuration
NFS options:
rpc.nsm.tcp.port -
rpc.nsm.udp.port -
rpc.mountd.tcp.port -
rpc.mountd.udp.port -
nfs.export.neg.timeout -
nfs.export.pos.timeout -
nfs.export.harvest.timeoutUse thevserver nfs modifycommand to modify the configuration of an NFS-enabled storage virtual machine (SVM).
Configurations that are functionally different in ONTAP
The following NFS configurations are functionally different in ONTAP:
NFS export rules
NFS export access cache
NFS diagnostic commands
Support for the
showmountcommand -
NFS Kerberos encryption
NLM version support
Related information
