Managing logical interfaces
You can add, edit, or remove 7-Mode IP addresses from a project.
The LIFs are configured on the storage virtual machine (SVM) in the apply configuration (precutover) phase:
Existing 7-Mode IP addresses are created in the administrative “down” state.
New IP addresses are created in the administrative “up” state.
FC and iSCSI LIFs are not transitioned by the 7-Mode Transition Tool. |
Perform one of the following actions:
If you want to… Then… Edit an existing LIF
Click
In the Modify LIF dialog box, make the required changes, and then click Save.
Remove an existing LIF
Click
in the table.You can remove a LIF only when the project is in the preparation, baseline data copy, pause, precutover, or update state. However, you cannot remove a LIF if the cutover operation has failed. -
Click Select 7-Mode LIF.
Select the 7-Mode IP addresses for transition.
Enter the target node and target port details.
Click Save.
Add a 7-Mode IP address
Click Save.
Add a new LIF
Click Add New LIF below the table.
Enter the required values.
Click Save.
