Recovering from a failed LUN transition
Download PDF of this page
If the transition of volumes with LUNs fails, you can use the lun transition 7-mode show command to check which LUNs were not transitioned to ONTAP, and then determine a corrective action.
Change to advanced privilege level:
set -privilege advanced -
Check which LUNs failed:
lun transition 7-mode show -
Review the EMS logs and determine the corrective action that you must take.
Perform the required steps shown in the EMS message to correct the failure.
If any supported LUNs failed the transition, then to complete the transition:
lun transition start -
View the transition status of the volumes:
lun transition showThe transition status can be one of following values:
active: The volume is in an active SnapMirror transition relationship and not yet transitioned. -
complete: All supported LUNs are transitioned for this volume. -
failed: LUN transition failed for the volume. -
none: The volume did not contain LUNs to transition from 7-Mode systems.
cluster1::*> lun transition show Vserver Volume Transition Status -------------------- ------------------ ----------------- vs1 vol0 none vol1 complete vol2 failed vol3 active -
Edit on GitHub
