Preparing Linux guest operating systems for transition
Download PDF of this page
If have 7-Mode LUNs mapped as physical compatible RDM (PTRDM) to Linux virtual machines (VMs) for the boot device, there are steps you must perform to prepare your Linux VMs for transition.
For copy-based transitions, perform these steps before initiating the Storage Cutover operation in the 7-Mode Transition Tool (7MTT).
For copy-free transitions, perform these steps before initiating the Export & Halt 7-Mode Systems operation in the 7MTT.
Obtain the SCSI device serial numbers:
cat /boot/grub/menu.lstIn the following example, 360a9800032466879362b45777447462d-part2 and 360a9800032466879362b45777447462d-part1 are SCSI device numbers:
# cat /boot/grub/menu.lst ... kernel /boot/vmlinuz-3.0.13-0.27-default root=/dev/disk/by-id/scsi- 360a9800032466879362b45777447462d-part2 resume=/dev/disk/by-id/scsi- 360a9800032466879362b45777447462d-part1
Determine the mapping between the SCSI device serial numbers and SCSI devices/partitions:
# ls -l /dev/disk/by-idThe following example shows how the relationship mapping is displayed. The
SCSI devices/partitionsare displayed following theSCSI device/partition serial numbers. In this example,../../sda, ../../sda1, and ../../sda2are SCSI devices/partitions.lrwxrwxrwx 1 root root 9 Oct 27 06:54 scsi-360a9800032466879362b45777447462d -> ../../sda lrwxrwxrwx 1 root root 10 Oct 27 05:09 scsi-360a9800032466879362b45777447462d-part1 -> ../../sda1 lrwxrwxrwx 1 root root 10 Oct 27 02:21 scsi-360a9800032466879362b45777447462d-part2 -> ../../sda2
Determine the mapping between the SCSI device paths and the UUIDs:
ls -l /dev/disk/by-uuidThe following example shows how the relationship mapping is displayed. In this example,
33d43a8b-cfae-4ac4-9355-36b479cfa524is the UUID for SCSI device/partition sda2`,603e01f8-7873-440a-9182-878abff17143is the UUID for SCSI device/partition sdb, andc50b757b-0817-4c19-8291-0d14938f7f0fis the UUID for SCSI device/partition sda1.lrwxrwxrwx 1 root root 10 Oct 27 02:21 33d43a8b-cfae-4ac4-9355-36b479cfa524 -> ../../sda2 lrwxrwxrwx 1 root root 9 Oct 27 06:54 603e01f8-7873-440a-9182-878abff17143 -> ../../sdb lrwxrwxrwx 1 root root 10 Oct 27 05:09 c50b757b-0817-4c19-8291-0d14938f7f0f -> ../../sda1
Use the UUID to update the device reference in the grub boot
menu.lstfile by matching it with the SCSI device path and SCSI serial number.#blkid /dev/sda1: UUID="c50b757b-0817-4c19-8291-0d14938f7f0f" TYPE="swap" /dev/sda2: UUID="33d43a8b-cfae-4ac4-9355-36b479cfa524" TYPE="ext3" /dev/sdb: UUID="603e01f8-7873-440a-9182-878abff17143" SEC_TYPE="ext2" TYPE="ext3"
Use the UUID you just retrieved to update the device reference in the grub boot
menu.lstfile.The following example shows the
menu.lstfile after it has been updated:# Modified by YaST2. Last modification on Fri Oct 17 02:08:40 EDT 2014 default 0 timeout 8 ##YaST - generic_mbr gfxmenu (hd0,1)/boot/message ##YaST - activate ###Don't change this comment - YaST2 identifier: Original name: linux### title SUSE Linux Enterprise Server 11 SP2 - 3.0.13-0.27 root (hd0,1) kernel /boot/vmlinuz-3.0.13-0.27-default root=/dev/disk/by-uuid/e5127cdf-8b30- 418e-b0b2-35727161ef41 resume=/dev/disk/by-uuid/d9133964-d2d1-4e29-b064-7316c5ca5566 splash=silent crashkernel=128M-:64M showopts vga=0x314 initrd /boot/initrd-3.0.13-0.27-default
Update the
/etc/fstabfile:-
/etc/fstabfile.The following example shows an
/etc/fstabfile with a SCSI serial number:/dev/disk/by-id/scsi-360a9800032466879362b45777447462d-part1 swap swap defaults 0 0 /dev/disk/by-id/scsi-360a9800032466879362b45777447462d-part2 / ext3 acl,user_xattr 1 1 proc /proc proc defaults 0 0 sysfs /sys sysfs noauto 0 0 debugfs /sys/kernel/debug debugfs noauto 0 0 devpts /dev/pts devpts mode=0620,gid=5 0 0
Replace the reference to the SCSI serial number with the UUID.
/etc/fstabfile that has been updated to replace the SCSI serial number with the UUID:cat /etc/fstab UUID="c50b757b-0817-4c19-8291-0d14938f7f0f swap swap defaults 0 0 UUID="33d43a8b-cfae-4ac4-9355-36b479cfa524 / ext3 acl,user_xattr 1 1 proc /proc proc defaults 0 0 sysfs /sys sysfs noauto 0 0 debugfs /sys/kernel/debug debugfs noauto 0 0 devpts /dev/pts devpts mode=0620,gid=5 0 0
Edit on GitHub
