Update firmware on an AFX storage system
Contributors dmp-netapp
ONTAP automatically downloads and updates firmware and system files on your AFX storage system by default. If you want to view the recommended updates before they are downloaded and installed, you can disable automated updates. You can also edit update parameters to show you notifications of available updates before any action is performed.
Enable automatic updates
When you enable automatic updates for your AFX cluster, recommended updates for storage firmware, SP/BMC firmware and system files are automatically downloaded and installed by default.
Steps
  1. In System Manager, select Cluster and then Settings.
  2. Under Software updates select Enable.
  3. Read the EULA.
  4. Accept the defaults to Show notification of recommended updates. Optionally, select to Automatically update or to Automatically dismiss recommended updates.
  5. Select to acknowledge that your update modifications will be applied to all current and future updates.
  6. Select Save.
Result
Recommended updates are automatically downloaded and installed on your ONTAP AFX system based upon your update selections.
Disable automatic updates
Disable automatic updates if you want the flexibility to view recommended updates before they are installed. If you disable automatic updates, you need to perform firmware and system file updates manually.
Steps
  1. In System Manager, select Cluster > Settings.
  2. Under Software updates, select Disable.
Result
Automatic updates are disabled. You should regularly check for recommended updates and decide if you want to perform a manual installation.
View automatic updates
View a list of firmware and system file updates that have been downloaded to your cluster and are scheduled for automatic installation. Also view updates that have been previously automatically installed.
Steps
  2. Next to Software updates select blue arrow pointing to the right, then select View all automatic updates.
Edit automatic updates
You can select to have recommended updates for your storage firmware, SP/BMC firmware and your system files automatically downloaded and installed on your cluster, or you can select to have recommended updates automatically dismissed. If you want to manually control installation or dismissal of updates, select to be notified when a recommended update is available; then you can manually select to install or dismiss it.
Steps
  2. Next to Software updates select blue arrow pointing to the right and then select All other updates.
  3. Update the selections for automatic updates.
  4. Select Save.
Result
Automatic updates are modified based on your selections.
Update firmware manually
If you want the flexibility of viewing recommended updates before they are downloaded and installed, you can disable automated updates and update your firmware manually.
Steps
  1. Download your firmware update file to a server or local client.
  2. In System Manager, select Cluster > Overview, then select All other updates.
  3. Under Manual Updates, select Add firmware files; then select Download from the server or Upload from the local client.
  4. Install the firmware update file.
Result
Your firmware is updated.
