View the AFX storage system dashboard
You can sign in to System Manager to access the AFX dashboard and display the cluster status. This is a good first step before beginning your AFX administrative tasks or if you suspect an operational issue.
You'll need the following:
IP address or domain name of the cluster management LIF
Administrator account credentials
Connect to System Manager using a browser and the cluster management IP address:
https://$FQDN_IPADDR/Example
https://10.61.25.33/ -
Provide the username and password for the administrator account and select Sign in.
Select Dashboard in the left navigation pane and review the tiles on the page including the cluster Health.
In the navigation pane, select Cluster and then Overview.
Review the cluster name, version, ONTAP personality and the other details.
At the top of the overview page, select Cabling for a visual display of the cluster hardware and connections.
In the navigation pane, select Events & Jobs and then System alerts to display and review the system alerts.
