View Insights to optimize your AFX storage system
Contributors dmp-netapp
You can use the Insights feature of ONTAP System Manager to display suggested configuration updates that align with NetApp best practices. These changes can optimize the security and performance of your AFX cluster.
For example, the Autonomous Ransomware Protection (ARP) feature is available with AFX and provides anti-ransomware protection. Insights will inform you if ARP is not configured.
About this task
Each of the insights is presented as a separate tile or card on the page that you can choose to implement or dismiss. You can also select the associated documentation link to learn more about a specific technology.
Steps
  1. In System Manager, select Analysis and then Insights.
  2. Review the available recommendations.
What's next
Perform any of the recommended actions to implement AFX configuration best practices.
