Supported configurations for your AFX 2K storage system
Learn about the supported hardware components and cabling options for the AFX 2K storage system, including compatible storage disk shelves, switches, and cable types required for proper system setup.
Supported AFX 2K cabling configuration
The initial configuration of the AFX 2K storage system supports a minimum of four controller nodes connected through dual switches to the storage disk shelves.
Additional controller nodes and disk shelves expand the initial AFX 2K storage system configuration. Expanded AFX 2K configurations follow the same switch-based cabling methodology as the schema depicted below.
Supported hardware components
Review the compatible storage disk shelves, switches, and cable types for the AFX 2K storage system.
| Hardware Component | Supported Cables |
AFX 2K (Controller Shelf) |
NX224 (Disk Shelf) |
Cisco Nexus 9808 (Switch) |
Cisco Nexus 9332D-GX2B (Switch) |
Cisco Nexus 9364D-GX2A (Switch) |
After reviewing the supported system configuration and hardware components, review the network requirements for your AFX 2K storage system.
