Manage the AFX storage system volumes
There are several administrative tasks you can perform as part of administering the volumes defined at your AFX cluster.
Create a qtree
A qtree is a logical subdivision within a volume that you can create to organize and administer data.
In System Manager, select Storage and then Qtrees.
Select
and provide the basic configuration including name, volume, and security style; optionally configure a quota. -
Select Save to add the qtree.
Create a quota
A quota is a limit set on the amount of storage space or number of files that can be used by a user, group, or qtree. Quotas are used to manage and control resource usage within an AFX system.
In System Manager, select Storage and then Quotas.
Select the Usage tab to display a list of the active quotas across all volumes.
Select the Volumes tab to display a list of the volumes defined in the AFX cluster; select a specific volume to display additional information.
To define a quota, select the Rules tab.
Provide the configuration details, including the quota target, type and limits.
Select Save to add the quota.
