Create a consistency group on an AFX storage system
You can create consistency groups to simplify storage management and data protection for application workloads. A consistency group can be based on existing or new volumes.
Before you begin
If you plan to create one more more new volumes, you should become with the configuration options when creating a ne volume.
Steps
In System Manager, select Protection and then Consistency groups.
Select
and choose one of:-
Using existing volumes
Using new NAS volumes
Provide the configuration details, including name, volumes, application type, and protection.
Select Add.
Related information
