Create an intercluster SVM peer relationship on an AFX storage system
A peer relationship defines network connections that enable clusters and storage virtual machine (VM) to exchange data securely. You can create a peer relationship between storage VMs on different clusters to enable data protection and disaster recovery using SnapMirror.
Before you begin
You must have established a cluster peer relationship between the local and remote clusters before you can create a storage VM peer relationship. Create a cluster peer relationship if you have not already done so.
Steps
In System Manager, select Protection > Overview.
Under Storage VM peers select Add a storage VM peer.
Select the storage VM on the local cluster; then select the storage VM on the remote cluster.
Select Add a storage VM peer.
Related information
