Thin provisioning
Thin provisioning for an Oracle database on ASA r2 requires careful planning because it involves configuring more logical space than is physically available. When implemented correctly, thin provisioning delivers significant cost savings and improved manageability.
Thin provisioning is integral to ASA r2 and closely related to ONTAP efficiency technologies because both allow more logical data to be stored than the physical capacity on the system. ASA r2 systems are SAN-only, and thin provisioning applies to storage units and LUNs within Storage Availability Zones (SAZ).
ASA r2 storage units are thin provisioned by default. |
Almost any use of snapshots involves thin provisioning. For example, a typical 10 TiB database with 30 days of snapshots might appear as 310 TiB of logical data, but only 12 TiB to 15 TiB of physical space is consumed because snapshots store only changed blocks.
Similarly, cloning is another form of thin provisioning. A development environment with 40 clones of an 80 TiB database would require 3.2 PiB if fully written, but in practice consumes far less because only changes are stored.
Space management
Some care must be taken with thin provisioning in an application environment because data change rates can increase unexpectedly. For example, space consumption due to snapshots can grow rapidly if database tables are reindexed, or wide-scale patching is applied to VMware guests. A misplaced backup can write a large amount of data in a very short time. Finally, it can be difficult to recover some applications if a LUN runs out of free space unexpectedly.
In ASA r2, these risks are mitigated through thin provisioning, proactive monitoring, and LUN resize policies, rather than ONTAP features like volume-autogrow or snapshot-autodelete. Administrators should:
Enable thin provisioning on LUNs (
space-reserve disabled) - this is the default setting in ASA r2 -
Monitor capacity using System Manager alerts or API-based automation
Use scheduled or scripted LUN resize to accommodate growth
Configure snapshot reserve and automatic snapshot deletion via System Manager (GUI)
Careful planning of space thresholds and automation scripts is essential because ASA r2 does not support automatic volume growth or CLI-driven snapshot deletion. |
ASA r2 does not use fractional reserve settings because it is a SAN-only architecture that abstracts WAFL-based volume options. Instead, space efficiency and overwrite protection are managed at the LUN level. For example, if you have a 250 GiB LUN provisioned from a storage unit, snapshots consume space based on actual block changes rather than reserving an equal amount of space upfront. This eliminates the need for large static reservations, which were common in traditional ONTAP environments using fractional reserve.
If guaranteed overwrite protection is required and monitoring is not feasible, administrators should provision sufficient capacity in the storage unit and set snapshot reserve appropriately. However, ASA r2's design makes fractional reserve unnecessary for most workloads. |
Compression and deduplication
Compression and deduplication in ASA r2 are space efficiency technologies, not traditional thin provisioning mechanisms. These features reduce the physical storage footprint by eliminating redundant data and compressing blocks, allowing more logical data to be stored than the raw capacity would otherwise permit.
For example, a 50 TiB dataset might compress to 30 TiB, saving 20 TiB of physical space. From the application perspective, there is still 50 TiB of data, even though it occupies only 30 TiB on disk.
The compressibility of a dataset can change over time, which may increase physical space consumption. Therefore, compression and deduplication must be managed proactively through monitoring and capacity planning. |
Free space and LVM space allocation
Thin provisioning in ASA r2 environments can lose efficiency over time if deleted blocks are not reclaimed. Unless space is released using TRIM/UNMAP or overwritten with zeros (via ASMRU - Automatic Space Management and Reclamation Utility), deleted data continues to consume physical capacity. In many Oracle database environments, thin provisioning offers limited benefit because datafiles are typically pre-allocated to their full size during creation.
Careful planning of LVM configuration can improve efficiency and minimize the need for storage provisioning and LUN resizing. When an LVM such as Veritas VxVM or Oracle ASM is used, the underlying LUNs are divided into extents that are only used when needed. For example, if a dataset begins at 2 TiB in size but could grow to 10 TiB over time, this dataset could be placed on 10 TiB of thin-provisioned LUNs organized in an LVM diskgroup. It would occupy only 2 TiB of space at the time of creation and would only claim additional space as extents are allocated to accommodate data growth. This process is safe as long as space is monitored.
