LUN placement
Optimal placement of database LUNs within ASA r2 systems primarily depends on how various ONTAP features will be used.
In ASA r2 systems, storage units (LUNs or NVMe namespaces) are created from a simplified storage layer called Storage Availability Zones (SAZs), which act as common pools of storage for an HA pair.
There is typically only one storage availability zone (SAZ) per HA pair. |
Storage Availability Zones (SAZ)
In ASA r2 systems, volumes are still there, but they are automatically created when storage units are created. Storage units (LUNs or NVMe namespaces) are provisioned directly within the automatically created volumes in Storage Availability Zones (SAZs). This design eliminates the need for manual volume management and makes provisioning more direct and streamlined for block workloads like Oracle databases.
SAZs and Storage units
Related storage units (LUNs or NVMe namespaces) are normally co-located within a single Storage Availability Zone (SAZ). For example, a database that requires 10 storage units (LUNs) would typically have all 10 units placed in the same SAZ for simplicity and performance.
In context of FC SAN, here storage unit refers to LUN. |
Consistency Groups (CGs), LUNs, and snapshots
In ASA r2, snapshot policies and schedules are applied at the Consistency Group level, which is a logical construct that groups multiple LUNs or NVMe namespaces for coordinated data protection. A dataset that consists of 10 LUNs would require only a single snapshot policy when those LUNs are part of the same Consistency Group.
Consistency Groups ensure atomic snapshot operations across all included LUNs. For example, a database that resides on 10 LUNs, or a VMware-based application environment consisting of 10 different OSs, can be protected as a single, consistent object if the underlying LUNs are grouped in the same consistency group. If they are placed in different consistency groups, snapshots may or may not be perfectly synchronized, even if scheduled at the same time.
In some cases, a related set of LUNs might need to be split into two different consistency groups because of recovery requirements. For example, a database might have four LUNs for datafiles and two LUNs for logs. In this case, a datafile consistency group with 4 LUNs and a log consistency group with 2 LUNs might be the best option. The reason is independent recoverability: the datafile consistency group could be selectively restored to an earlier state, meaning all four LUNs would be reverted to the state of the snapshot, while the log consistency group with its critical data would remain unaffected.
CGs, LUNs, and SnapMirror
SnapMirror policies and operations are, like snapshot operations, performed on the consistency group, not the LUN.
Co-locating related LUNs in a single consistency group allows you to create a single SnapMirror relationship and update all contained data with a single update. As with snapshots, the update will also be an atomic operation. The SnapMirror destination would be guaranteed to have a single point-in-time replica of the source LUNs. If the LUNs were spread across multiple consistency groups, the replicas may or may not be consistent with one another.
SnapMirror replication on ASA r2 systems has the following limitations:
Learn more about SnapMirror replication policies supported on ASA r2 systems. |
CGs, LUNs, and QoS
While QoS can be selectively applied to individual LUNs, it is usually easier to set it at the consistency group level. For example, all of the LUNs used by the guests in a given ESX server could be placed in a single consistency group, and then an ONTAP adaptive QoS policy could be applied. The result is a self-scaling IOPS-per-TiB limit that applies to all LUNs.
Likewise, if a database required 100K IOPS and occupied 10 LUNs, it would be easier to set a single 100K IOPS limit on a single consistency group than to set 10 individual 10K IOPS limits, one on each LUN.
Multiple CG layouts
There are some cases where distributing LUNs across multiple consistency groups may be beneficial. The primary reason is controller striping. For example, an HA ASA r2 storage system might be hosting a single Oracle database where the full processing and caching potential of each controller is required. In this case, a typical design would be to place half of the LUNs in a single consistency group on controller 1, and the other half of the LUNs in a single consistency group on controller 2.
Similarly, for environments hosting many databases, distributing LUNs across multiple consistency groups can ensure balanced controller utilization. For example, an HA system hosting 100 databases of 10 LUNs each might assign 5 LUNs to a consistency group on controller 1 and 5 LUNs to a consistency group on controller 2 per database. This guarantees symmetric loading as additional databases are provisioned.
None of these examples involve a 1:1 LUN-to-consistency group ratio, though. The goal remains to optimize manageability by grouping related LUNs logically in consistency group.
One example where a 1:1 LUN to consistency group ratio makes sense is containerized workloads, where each LUN might really represent a single workload requiring separate snapshot and replication policies and thus need to be managed on an individual basis. In such cases, a 1:1 ratio may be optimal.
