Oracle and SnapMirror active sync failover
Planning a complete SnapMirror active sync application architecture requires understanding how SM-as will respond in various planned and unplanned failover scenarios.
For the following examples, assume that site A is configured as the preferred site.
Loss of replication connectivity
If SM-as replication is interrupted, write IO cannot be completed because it would be impossible for a cluster to replicate changes to the opposite site.
Site A (Preferred site)
The result of replication link failure on the preferred site will be an approximate 15 second pause in write IO processing as ONTAP retries replicated write operations before it determines that the replication link is genuinely unreachable. After the 15 seconds elapses, the site A system resumes read and write IO processing. The SAN paths will not change, and the LUNs will remain online.
Site B
Since site B is not the SnapMirror active sync preferred site, its LUN paths will become unavailable after about 15 seconds.
Storage system failure
The result of a storage system failure is nearly identical to the result of losing the replication link. The surviving site should experience a roughly 15 second IO pause. Once that 15 second period elapses, IO will resume on that site as usual.
Loss of the mediator
The mediator service does not directly control storage operations. It functions as an alternate control path between clusters. It exists primarily to automate failover without the risk of a split-brain scenario. In normal operation, each cluster is replicating changes to its partner, and each cluster therefore can verify that the partner cluster is online and serving data. If the replication link failed, replication would cease.
The reason a mediator is required for safe automated failover is because it would otherwise be impossible for a storage cluster to be able to determine whether loss of bidirectional communication was the result of a network outage or actual storage failure.
The mediator provides an alternate path for each cluster to verify the health of its partner. The scenarios are as follows:
If a cluster can contact its partner directly, replication services are operational. No action required.
If a preferred site cannot contact its partner directly or via the mediator, it will assume the partner is either actually unavailable or was isolated and has taken its LUN paths offline. The preferred site will then proceed to release the RPO=0 state and continue processing both read and write IO.
If a non-preferred site cannot contact its partner directly, but can contact it via the mediator, it will take its paths offline and await the return of the replication connection.
If a non-preferred site cannot contact its partner directly or via an operational mediator, it will assume the partner is either actually unavailable or was isolated and has taken its LUN paths offline. The non-preferred site will then proceed to release the RPO=0 state and continue processing both read and write IO. It will assume the role of the replication source and will become the new preferred site.
If the mediator is wholly unavailable:
Failure of replication services for any reason, including failure of the nonpreferred site or storage system, will result in the preferred site releasing the RPO=0 state and resuming read and write IO processing. The non-preferred site will take its paths offline.
Failure of the preferred site will result in an outage because the non-preferred site will be unable to verify that the opposite site is truly offline and therefore it would not be safe for the nonpreferred site to resume services.
Restoring services
After a failure is resolved, such as restoring site-to-site connectivity or powering on a failed system, the SnapMirror active sync endpoints will automatically detect the presence of a faulty replication relationship and bring it back to an RPO=0 state. Once synchronous replication is reestablished, the failed paths will come online again.
In many cases, clustered applications will automatically detect the return of failed paths, and those applications will also come back online. In other cases, a host-level SAN scan may be required, or applications may need to be brought back online manually. It depends on the application and how it is configured, and in general such tasks can be easily automated. ONTAP itself is self-healing and should not require any user intervention to resume RPO=0 storage operations.
Manual failover
Changing the preferred site requires a simple operation. IO will pause for a second or two as authority over replication behavior switches between clusters, but IO is otherwise unaffected.
