Get more information
There are several additional resources you can access to get help and find more information about how to automate the deployment and administration of your ONTAP storage systems.
ONTAP 9 resources
Provides all of the documentation for ONTAP 9.
ONTAP and ONTAP System Manager Resources
Provides documentation and other helpful links needed to plan, administer, and support ONTAP 9.
ONTAP 9 developer resources
ONTAPI to REST API mapping information
Provides the key ONTAPI calls and the mapping to the equivalent REST API calls.
NetApp Developer Network: ONTAP RESTful API
Provides resources and documentation needed to use the ONTAP REST API, including the ONTAP Python client library.
Videos
Getting started with the NetApp ONTAP Python client library
Good introduction to the NetApp Python client library and how to get started writing code using the library.
Blogs
Get started with automating your dev work flows with NetApp and Ansible
If you’re new to using Ansible for ONTAP automation, this is a good place to start.
NetApp resources
Access troubleshooting tools, documentation, and technical support assistance.
NetApp Interoperability Matrix Tool
Access requirements and compatibility information related to using ONTAP 9 and the ONTAP REST API.
NetApp library of technical reports and white papers
Access technical reports, white papers, and other documents.
